Air comming from dipstick tube ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2007, 05:24 PM   #1 (permalink)
View Heatproof's Photo Gallery
4th Generation Air comming from dipstick tube ?
I was wondering, Is normal for air to be coming out of the dipstick tube while the engine is running ? I have a gen 4 Camry ce I4 around 77,000 miles on the clock.
Edited to add:
I was topping off the oil and forgot to put the dipstick back in before I started the engine and notticed air comming from the tube.
I replaced the pcv valve and it is working But there is still air coming from the tube.
Would there be any thing other than pcv that would couse it ?
Heatproof is offline   Reply With Quote
Old 09-22-2007, 07:03 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Is air coming out of the dipstick tube when the dipstick is all the way in....or are you (for some reason Id like to know) trying to check the oil while the engine is running?!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 09-22-2007, 08:31 PM   #3 (permalink)
The Greatest
View CamNub's Photo Gallery
No, this is not normal.
And I would venture to say it is very very serious.
I know for Volvos, the same symptoms is caused by the PCV system getting clogged. Eventually, so much pressure builds up that your rear main seal will blow out (you need to take out motor to replace it).
You want positive crankcase pressure which means that it should be sucking in.
CamNub is offline   Reply With Quote
Old 09-22-2007, 11:49 PM   #4 (permalink)
DJT853's Avatar
View DJT853's Photo Gallery
bad....Bad...BAD...
I would take it to a shop, but thats just me. Knowing me, major DIY repairs would end in failure
Dougy
My ride: The 2000 Camry LE I4 in Silver
DJT853 is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
K&N air filter vs K&N cold air intake dsulu 89-95 Toyota Pickup/Hilux 12 01-14-2007 12:04 PM
I need an air intake tube for my 5sfe. nyluder 3rd & 4th Generation (1992–1996 & 1997–2001) 1 11-26-2006 07:47 AM
Short air intake question rabinny Archived Corolla threads 55 11-25-2005 08:01 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
