96 Camry 2.2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2007, 03:59 PM   #1 (permalink)
View shermanreed's Photo Gallery
96 Camry 2.2
I recently bought a 96 Camry that had a motor swapped out by a competent mechanic. He replaced the water pump, oil pump, head gasket, valve cover gaskets, had the head plained, put in all new front seals, rear seals, etc. The car is running perfect. However, it has a slight oil leak - I cannot tell exactly where it is coming from.
When he sold me the car he told me about it and said he had replaced the valve cover gaskets a second time. It has not eliminated the leak - keep in mind the leak is not severe. He also said he replaced the distributor bearing because he thought it may have been coming from there.
It looks to me like maybe the power steering shaft seal is where it is coming from. Is this a possibility? BTW, when I make a hard turn the ps whines real loud. I also notice from under the car that there is a little oil under the distributor - could the seal be bad - seems like that would have been replaced when the bearing was replaced. It is definitely up high and on the back side - not the valve cover. What do you think?
shermanreed is offline   Reply With Quote
Old 09-25-2007, 10:44 PM   #2 (permalink)
View popeye08's Photo Gallery
Check this link:
http://toyotanation.com/forum/t124228.html
oil could leak out of the timing belt cover in the first pic.
popeye08 is offline   Reply With Quote
Old 09-26-2007, 12:13 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
there is also a rubber o-ring around the distributor which is prone to leaks.
how is the fluid level in the power steering? also the color of the fluid. it should look pink like transmission fluid (because it is).
Old 09-26-2007, 06:02 PM   #4 (permalink)
I noticed today that it is low - obviously it is leaking. I will check color tomorrow.
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Techna-fit Brake/Clutch Line Group Buy: All Makes/Models raptorracing Supporting Vendor Sales 230 08-27-2007 12:22 AM
Cheap & easy performance upgrades for 96 V6 camry??? eastman 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-18-2007 05:01 PM
want to buy 96 camry hood,front bumper,headlights,corner lights. bumper lights.grill. umeshr85 Car parts for trade or wanted parts 1 08-04-2007 02:56 AM
96 camry 2.2, has spark and gas. No Start mpa4712 3rd & 4th Generation (1992–1996 & 1997–2001) 3 03-14-2007 01:00 AM
