Gen 4 - Whistling noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2007, 04:50 PM   #1 (permalink)
View mgreenly's Photo Gallery
4th Generation Gen 4 - Whistling noise
When I accelerate hard I am getting a whistling noise that seems to come from under my car, sometimes in the front, sometimes center, sometimes it almost sounds like it's coming from the back...very hard to tell. It only happens when I accelerate hard and I can actually play with the pitch of the whistle with my foot on the gas pedal (yea i know...but i'm tired of hearin the damn whistle).
The intake is clear with all the hoses hooked up and tight, as far as I can see.
No hole in the exhaust.
Mechanic looked at it and drove around with me. He told me to change out the PCV Valve (small $6 part on top of the valve cover that connects to the intake manifold). And that hasn't helped. He also mentioned that it doesn't sound like anything major, possible just air sucking in somewhere.
Before I take it to the Toyota dealership to find out if they have had this problem before I wanted to ask you guys if anyone has come accross a similar problem?
The dealership is kinda far away so I wanted to ask you guys first. (plus I hate dealerships)
mgreenly is offline   Reply With Quote
Old 09-25-2007, 07:48 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Did you have your AC on?
2007 Camry 2.4L 5M
Old 09-25-2007, 08:50 PM   #3 (permalink)
View Life2's Photo Gallery
it's probably from one of the belts. My friends rodeo did that when it's serpentine belt was dieing.
96 camry v6 xle
91 mr2 n/a
Life2 is offline   Reply With Quote
Old 09-26-2007, 08:52 AM   #4 (permalink)
I believe it whistles both with the AC on and with the AC off. That's something I'll check again before I take it to the dealership.
An old mechanic where I worked checked the belts already (quickly tho) to make sure they weren't loose or worn. Plus I brought it up to the most recent mechanic that looked at it, too. And he said he doesn't think that's what it is either. Then again if I may not be able to tell until I (or someone) actually remove the belts to inspect them.
Old 09-26-2007, 10:27 AM   #5 (permalink)
View Novice_cardude's Photo Gallery
It's a long shot, but it could be alternator or water pump whine. More likely alternator whine. A whine is different from a whistle, and the alternator usually only whines when it's being stressed to pump out a lot of current.
Only reason I bring this up is I put a reman. alternator on a Saturn once, and drove it around before charging the battery. Because the alternator was hard pressed to charge the battery and provide current for the rest of the loads, it would whine, most noticeably while accelerating.
I'd just get a quick battery check done if it's a few years old and see what shape it's in.
Novice_cardude is offline   Reply With Quote
Old 09-26-2007, 11:22 AM   #6 (permalink)
View shimpi's Photo Gallery
My wifes 97 Rav-4 makes the same "whistling" sound during full throttle acceleration. Up until now, I always thought it was the air intake, but now I am not so sure. What I do know is when the car is in park and I hit the gas, I don't hear the sound. However when the car is in drive and I hit the gas to do full acceleration, that's when I hear the sound. It only happens when it is in gear.
shimpi is offline   Reply With Quote
Old 09-27-2007, 01:49 AM   #7 (permalink)
What you described is exactly how my "whistle" is. It honestly sounds like air escaping or being sucked in through some small opening.
Old 09-27-2007, 06:57 AM   #8 (permalink)
atomix099's Avatar
View atomix099's Photo Gallery
Yup i have the same problem... Same exact problem...
I just recently changed out my battery to a optima red top and new battery cables... My battery before was dead to the point the radio wouldnt turn on until i drive it for a while, and the car would take forever to reach just 20mph, after i changed the battery everything runs fine... Im saying this because i beleive my alternator could be stressed out, i have no signs of it dieing since i changed the battery though...
My intake actually has a hole (looks like more of a slice) I duck taped it up as a temp until my intake arrives... So im ur same boat... it could be either one
Tork Imagine Gloss Black 18x8-9/ 14% Tint - 20% Rear Glass
Kenwood KDC-MP208 / Premier TS-W1241C x2
http://www.cardomain.com/ride/2371652
atomix099 is offline   Reply With Quote
Old 09-27-2007, 07:57 AM   #9 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Mine whistles too past 3500 rpms during harder acceleration. It almost sounds like my Camry has a turbo.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 12-04-2009, 11:17 AM   #10 (permalink)
View vmoua509's Photo Gallery
strange whistling coming from enging bay
i'm working on a completely stock 97 camry 5sfe engine. And a strange whistling noise is heard during hard accelerating from 3k rpms and higher. Only does it in drive and not in park or neutral. I'm also throwing code p0171 System too lean bank 1. I've replaced the primary o2 sensor twice already with a bosch universal o2 sensor. I've checked everything like the service manual says to check and still no luck!
Last thing i can think of is bad intake gaskets including egr valve and throttle body gaskets also or a cracked intake manifold??? Whats your thoughts on this....?
Any help is greatly appreciated!!! Thanks
vmoua509 is offline   Reply With Quote
HELP: clicking noise when i turn my wheel on my gen 3 Whitecamryghost 3rd & 4th Generation (1992–1996 & 1997–2001) 9 12-16-2006 06:55 AM
Corolla rattling noise near drive belt area Momaru Archived Corolla threads 8 09-07-2006 12:57 AM
Gen 3 Suspension Noise Poll - Lets figure this out RedPhoenix 3rd & 4th Generation (1992–1996 & 1997–2001) 6 07-08-2006 10:19 PM
Crunching noise in gen 4. caveman017 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-13-2006 03:21 PM
Help...excessive road noise islandx Tercel, Paseo, Starlet, and Sera Forum 5 02-01-2006 05:08 AM
