Hi,
Here is the problem: the engine on my 2000 camry 4 cylinder 5SFE runs rough at idle, especially when A/C is on and on stop lights. Otherwise no problems at all, no check engine light.
I replaced spark plugs twice, first I tried NGK then Bosch.
Cleaned throttle body.
Cleaned fuel injectors at toyota dealership.
Tried new plug wireset.
Replaced throttle position sensor (TPS)
Replaced PCV.
Cleaned EGR valve.
No results, the same rough idle like a missfire.
The sparkplugs I replace had no smell, no oil on them, no gas.
Also I noticed strange sound from the exhaustpipe like 'pa-pa-pa....'.
Today I disconnected the oxygen sensor in the engine compartment, no changes at all, I drove awhile and no check engine light.
Could it be the oxygen sensor causing the rough idle? And why there are no error codes?
Thank you.
