Gen3 3VZ & Towing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2007, 02:40 AM   #1 (permalink)
Toyota Camry Vienta CSi
View Aussie_Camry's Photo Gallery
Gen3 3VZ & Towing
Hey Guys... Im considering purchasing a boat (just a small open boat, 500kg or so in total) and was wandering, what is the max you can tow (unbraked trailer) on the 3VZ? I couldnt find what its rated for on any sites I know of, they only provided from Gen4 onwards (which could only tow 500kg). I ASSUME it could tow more then the Gen4, as the 3VZ has more torque down low (albeit less overall) and Im quite sure it has twin piston calipers unlike the Gen4.
Any help appreciated!
Aussie_Camry is offline   Reply With Quote
Old 09-27-2007, 03:06 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
about a ton, 907kg but i wouldnt tow that with my car. is that weight with the trailer or without? if thats with the trailer then u should be fine....jsut make sure ur brakes are working
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-27-2007, 05:24 PM   #3 (permalink)
View toyomoho's Photo Gallery
Check with your motor vehicle department on brake requirements, usually there is a weight limit beyond which trailer brakes are required. Towing 1 ton is very possible but would not want to do this for long distances or on any hills. Braking is OK but you will defiantly know the trailer is behind you.
500kg is fine without trailer brakes. Suggest you lockout the O/D on hills; make sure you do not overload the car even more by adding lots of passengers and trunk items. If you do tow on regular basis or take long trips suggest adding an oil cooler to keep trans fluid temps down. Or at least change the fluid more often.
Old 09-27-2007, 05:51 PM   #4 (permalink)
Thanks guys
Yeah its around 500-600kg with trailer... Im tempted to get a braked trailer (although I believe my Gen3 has twin piston calipers,.... one time going down a steep hill I had massive brake fade... they aernt the greatest brakes I suspect due to their size) and I was also thinking about a tranny cooler because I dont think my tranny is in a great state as is let alone towing something.
Towing question for an '04 PreRunner Red Dog 1st Generation (1995.5–2004) 5 07-18-2007 10:17 AM
Towing Package or Not? ForTech 2nd Generation (2005+) 16 04-06-2007 10:54 PM
Is there demand for a 3.4L or 4.0L V6 swap kit? QuadCamSix Camry & Solara Lounge 67 08-16-2006 09:16 PM
Gen2 3sfe (USDM) vs. Gen3 3sfe (JDM) - What's the Difference? airswoosh1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 12-24-2005 12:10 PM
Bumper Towing ? Bisch 2nd Generation (2005+) 4 08-26-2005 08:21 PM
