help with intake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2007, 02:13 AM   #1 (permalink)
The Original Weasel
View ChitownCamry01's Photo Gallery
Unhappy help with intake
ok so i've had my 01 camry LE for about 8 months and i finally added an intake (cheap eBay, saving to get an Injen) anyways i installed it and i just had to take it to emissions where it failed. i have 6 error codes; can anyone help me figure out what to do to pass? if you need to know the codes they are:
P0171 System too lean (bank one)
P0110 Intake Air Temp Circuit
P0401 EGR flow insufficient detected
P0440 EVAP control system
P0441 EVAP control system incorrect purge flow
P0446 EVAP control system vent control circuit
thanks for any help guys
Dream as if you'll live forever, live as if you'll die today
ChitownCamry01 is offline   Reply With Quote
Old 09-28-2007, 06:08 AM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
I'd reinstall the original intake, clear the codes and see if they come back. If not you can trace from there to the new intake. Lean and intake air temp probably related to new intake, not so sure about rest of codes.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 09-28-2007, 08:43 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
x2...just replace it for the time being.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 09-28-2007, 09:24 AM   #4 (permalink)
View wiccanferret's Photo Gallery
Replace it with the original intake to get past inspection.
Once you put the new intake back on, make sure you pull the negative battery cable for a few seconds to reset the car's ECU. This speeds up the air/fuel relearning process which I'm pretty sure is the problem.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 09-28-2007, 09:55 AM   #5 (permalink)
Athlon_64's Avatar
View Athlon_64's Photo Gallery
Hopefully that will work for you.
if P0401 comes back heres some threads...
http://toyotanation.com/forum/showthread.php?t=207745
http://toyotanation.com/forum/showthread.php?t=203018
http://toyotanation.com/forum/showthread.php?t=178186
ive personally had P0401 but it wasnt related to an intake, my vsv valve wound up being the issue.
try searching for the other codes here as well as on google
good luck!
Not Even Doom Music makes this sig cool
Athlon_64 is offline   Reply With Quote
Old 09-30-2007, 01:23 PM   #6 (permalink)
The Original Weasel
Thumbs up
thanks for all the help guys; i wound up just disconnecting the negative cable for about 5-7secs, put it back on and when i started the car, the check engine light went off . i'm having one of my co-workers b/f come in and scan it to see if any of the codes still pop up
New Idea For Intake (new to me at least lol) fistofmeat Archived Corolla threads 6 09-13-2006 05:20 PM
Air Temp. tube questions (Intake Install) Mousiee Camry & Solara Lounge 1 04-13-2006 05:17 PM
1996 Camry Intake Question Sniperdude 3rd & 4th Generation (1992–1996 & 1997–2001) 4 03-23-2006 06:59 PM
CA legal 5sfe performance? anuthaCamry MR2 Forum 26 02-19-2005 08:08 PM
