A/C Compressor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2007, 08:49 PM   #1 (permalink)
hav
View hav's Photo Gallery
4th Generation A/C Compressor
Hi,
I have 99' V6 Camry. It has around 120 K on the clock. Recently when I had the mechanic change the oil he said that there is a mild rattling noise coming from the compressor, when you stand outside the car near the front with the hood open. I turned the A/C from the cabin later, but I don't hear any noise. A/C blows cool but not chilly cold.
Do you think I need to change the compressor. I had all the belts changed recently.
Can an A/C recharge or servicing fix the problem?
Thanks
hav is offline   Reply With Quote
Old 09-30-2007, 04:37 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
My 1995 compressor is chattering too. I took it to an AC shop and they said that it was beginning to go. They put in some synthetic oil and said that it might last a little longer. I hope that it will last another season or two. When it does break I'll replace the compressor.
Kep
Old 09-30-2007, 07:04 PM   #3 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
dont change it until the cold air stops working ... its a $500+ expense
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 10-01-2007, 10:21 AM   #4 (permalink)
View hooRAH's Photo Gallery
Really the only way to be sure is to run a pressure test on the system. You'll need to take a look at both the high side pressure and the low side pressure to see if the compressor is working properly or if you are low on refrigerant.
A rattling in the compressor means that the bearings are wearing out. It might be a sign you need to replace it, but I've had 2 cars with bearings in the AC that make noise that have worked fine for over 5 years (each of them). Its not an immediate write off.
I'd take the car for a "free AC checkup" that shops run and have them give you the high and low side pressures (don't settle for a good/bad diagnosis). Then you can research the pressures on your own and decide if the compressor is working properly.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
A/C Compressor rebuild Pszemol 3rd & 4th Generation (1992–1996 & 1997–2001) 4 12-19-2006 11:54 AM
No A/C, no power to compressor, help! pcfrog General Discussion 2 08-15-2006 08:09 AM
A/C Compressor Question fj55mike 1st & 2nd Generation (1983–1986 & 1987-1991) 1 08-09-2006 02:55 PM
'89 Camry A/C Compressor Not Running 89DLXV6 1st & 2nd Generation (1983–1986 & 1987-1991) 7 08-27-2005 04:09 PM
