Some Reverse Gauges Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2007, 10:55 AM   #1 (permalink)
dpanda88's Avatar
iTrader Score: 7 reviews
View dpanda88's Photo Gallery
I was wondering if anyone who also has reverse gauges to help me out. So I put them on and connected them with the last wire on the right on the green connector. Now it all works and such but the backlight for the KM's and the needle doesn't lit. So at night time I can't really see anything but the nice colour of the reverse guages. Is it suppose to be like this? Or maybe I might have not connected it right?
Any help will be great. I would like to have all my lights lit at nighttime
2009 Matrix XR @ 2.4L
[Mods] Megan Coilovers Gen 1 on Gen 2 [SLAMMED], Custom front lip, Magnaflow 14818 exhaust with 2.25" custom straight pipe, XRS 09 FSB, TRD RSB, K&N Typhoon Intake, Ichiban 15mm Spacers, XRS 09 18" RIMS on BFGoodrich G-Force2
dpanda88 is offline   Reply With Quote
Old 09-30-2007, 03:25 PM   #2 (permalink)
Creeps228's Avatar
Gameroom cash: $274418
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
you did something wrong....completely wrong...I didnt touch any of the three connectors when i installed mine...i powers the gauges by connecting it to the tailights fuse and grounded in on the metal on the under the steering wheel, try disconnecting the guages and reconnecting the green wire see if the same things happen if it does than maybe you blew a fuse
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 10-01-2007, 09:22 AM   #3 (permalink)
dpanda88's Avatar
no it works.. I just reused my old gauges for the time being.. and everything lits up again.. but now I want to know what to do to make them all work including the reverse gauges
Old 10-01-2007, 08:56 PM   #4 (permalink)
dpanda88's Avatar
bump...
anyone have any personal guides on installing reverse gauges? I'm using the DIY from TN but it's causing me problems.. well wiring problems
Old 10-01-2007, 10:05 PM   #5 (permalink)
Creeps228's Avatar
connect it to the taillight fuse!
forget about DYIs im telling you connect it to your tail light fuse that way when your headlights/taillights are on the reverse glow guages will also also turn on
MR2: 7A-GE
Old 10-01-2007, 11:40 PM   #6 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $407745
View uibalnme's Photo Gallery
I just tapped into my cigarette lighter's light bulb wires. They're not critical, and they're easy to get to. Here's how mine turned out.
uibalnme is offline   Reply With Quote
Old 10-02-2007, 10:25 AM   #7 (permalink)
dpanda88's Avatar
where is the taillight fuse ??
Old 10-02-2007, 11:20 AM   #8 (permalink)
Creeps228's Avatar
the taillight fuse is located behind the "change pocket" on the drivers side, just tap into the fuse or do what i did, wrapped the power end of the gauges onto one of the teeth o fthe fuse and shoved it into place, it will work just fine. When ever your tailights go on they'll light up and NO THEY WONT LIGHT UP WHEN YOU PRESS THE BRAKES.
MR2: 7A-GE
Old 10-02-2007, 12:12 PM   #9 (permalink)
dpanda88's Avatar
oh i'll give it a try.. I'll probably shove it back into that little hole or the wire I cut and put together.. thanks I'll do my best
Old 10-02-2007, 04:00 PM   #10 (permalink)
Creeps228's Avatar
np let us know how its going
MR2: 7A-GE
Old 10-03-2007, 10:28 PM   #11 (permalink)
View Fredrick2003's Photo Gallery
This is why I just stuck to the stock gauges
Fredrick2003 is offline   Reply With Quote
Old 10-03-2007, 10:30 PM   #12 (permalink)
xet
View xet's Photo Gallery
it really isnt that bad, follow the guides and its really easy
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 10-03-2007, 10:49 PM   #13 (permalink)
Creeps228's Avatar
the only thing that must be done...well i suggest is top off on the gas, i moved mine but just to make sure it was working properly i topped off...dpanda if you want i'll take a pic oof my gauges
MR2: 7A-GE
Old 10-03-2007, 11:34 PM   #14 (permalink)
xet
dont worry i moved everything, i thought i brought my speedometer so i ordered a new one just happens that the speedo doesnt really move when im not using the pedal to move -_- anyone want a replacement speedo?
2005 G35 coupe 6mt
Old 12-26-2007, 01:26 AM   #15 (permalink)
Ballin Ass Camry
stewart591's Avatar
View stewart591's Photo Gallery
4th Generation
sorry for it being so late but son of a cock i cant get this shit working where the hell can i put the ground cable??? sorry for the language
stewart591 is offline   Reply With Quote
Reverse Light Switch/Connection k21xfr Celica Forum 0 08-08-2006 06:00 AM
01 camry reverse glow gauges stuntking40 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-11-2005 03:46 PM
Reverse Glow gauges 1999 Camry kdrk 3rd & 4th Generation (1992–1996 & 1997–2001) 11 04-02-2004 06:18 PM
celica all trac reverse or indiglow gauges??? kmystic16 Celica Forum 1 03-18-2004 02:22 PM
Anyone interested in Custom Gauges 92-96 Gen 3's?? Keyser Soze 3rd & 4th Generation (1992–1996 & 1997–2001) 49 06-23-2002 01:27 AM
