v6 swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2007, 10:28 PM   #1 (permalink)
View camryfreak09's Photo Gallery
3rd Generation v6 swap?
what would be cheaper doing a v6 swap into my gen3(friend has motor jack and tools to do it, he is currently doing an itr swap in his integra) or just go and buy a damn used v6. all the ones in houston look like crap and the motors are around 150k. i wanted to buy a jdm motor online and go to the junk yard for the other parts
camryfreak09 is offline   Reply With Quote
Old 09-30-2007, 10:37 PM   #2 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
umm that a good question i would say just get a v6 you will prob spend less money. but you can by the v6 if you want but i think that it would involve a lot more work and turn out more costly
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 09-30-2007, 10:42 PM   #3 (permalink)
View GTO MAN's Photo Gallery
Unhappy Bad miss in my 87
I am sorry if i am posting in the wrong place, On my #4 plug wire when i pull it off it does not change my rpms at all. Any one know what it could be? I thank any one for some help i have changed the cap. Need some help please. TKS randy.
GTO MAN is offline   Reply With Quote
Old 09-30-2007, 10:44 PM   #4 (permalink)
xet
View xet's Photo Gallery
make a new thread with your problem
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 09-30-2007, 10:48 PM   #5 (permalink)
2nd Generation Bad miss in my 87 second gen camara
I can pull the 4th cilender plug wire off with no rpm drop, Please help.
Old 09-30-2007, 10:54 PM   #6 (permalink)
Thank you xet.
Old 09-30-2007, 10:54 PM   #7 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
You basically need a V6 front clip. Find a totaled V6 Camry with an untouched front end. Drop the subframe from the V6 with EVERYTHING attacked (wiring, engine, tranny, struts, wheels, brakes, etc), and put it all on your car just like that. And you may need to change your dash harness to the one from the V6.
Yes, that engine is an I4 (Was in the white car the day before), and yes, that is a V6 in the car. :-D
5 Lug Corolla WHAT?
Old 09-30-2007, 10:57 PM   #8 (permalink)
Lone star
blackhawk's Avatar
^how much work was it if you don't mind me asking and how much time did it take / money^
Old 10-01-2007, 01:42 AM   #9 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
You are better off just buying the v6 and swapping a newer v6 in later, saves you from a lot of headaches.
-SCWEET1- is offline   Reply With Quote
Old 10-01-2007, 01:56 AM   #10 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
better to buy the car that came with the v6 not to mention that its less hassle and probably cheaper already. Already comes with the v6 disc brakes all around and little things like speedometer readings will right with the stock v6 wheels. It's just better to buy the v6 one period.
felonyr301 is offline   Reply With Quote
Old 10-01-2007, 02:24 AM   #11 (permalink)
xet
^agreed and get a 5spd if possible and save yourself even more troubles!
2005 G35 coupe 6mt
Old 10-01-2007, 09:50 AM   #12 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
i did the entire swap for 400bucks...1992 4cyl xle into a full on 1993 v6 xle brakes exhaust suspension. unless you've done it you have no idea how difficult it is.....
camryfreak09: call local towyards and see if they have one they are willing to sell as a parts car only. then you will have everything you need for your swap. that's what i did. also the only difference in the ac compressor is the pulley.
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Is there demand for a 3.4L or 4.0L V6 swap kit? QuadCamSix Camry & Solara Lounge 67 08-16-2006 09:16 PM
screw V6 swap bpcamrydude Camry & Solara Lounge 15 08-12-2004 02:56 PM
swap a V6 into my I-4? what about a lexus ES300 or IS300? bpcamrydude Camry & Solara Lounge 3 08-06-2004 10:45 AM
couple questions about 4cyl to V6 swap Pooge Camry & Solara Lounge 12 05-12-2004 03:57 AM
