brakes keep moving forward and squeal rummber noise before completed stop
i changed 98 toyota camry with new toyo pads and rotor. i noticed when i did a test drive, if i perfomed a quick stop..the car move forward with a romer noise before its stop completely. also, i know the brake padel feels little harder (more friction) when push padel down...is that normal? read brakes shoes look new, so i only adjusted the back brake only. can the noise be something i worry or just like that? sometimes i heard the romer noise (like the pad rub against and moving forward a little before its complete stop)
but other that, the car 98 toyo camry runs fine. Also, i put new pad and both front new toyo rotors...when i look Right passenser side rotor is has a mark circle on the new rotor...can it be something that rob brakes pad to cause that? how can i fixed it or just normal?
thanks
