Ignition Timing Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2007, 02:38 PM   #1 (permalink)
View crfjeff's Photo Gallery
I think the timing is off on my 1994 Camry (4 cyl.). Any tips on how to adjust that without going to a mechanic? I have tried rotating the distributor, and that helped, but I can not get it so it runs perfectly. Right now it pings.
crfjeff is offline   Reply With Quote
Old 10-01-2007, 02:59 PM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Get a timing light and see what you're timing is set at currently. Also, you might want to rotate the engine to tdc (top dead center) and see if your crank pulley mark is at zero degrees or within a few degrees. Perhaps your belt slipped a tooth or two and that's what's throwing you off, I dunno.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Noob question does my echo have a timing belt or timing chain? tousi Yaris, Vitz and Echo Forum 1 09-02-2006 01:36 PM
94 Toyota Pickup 22re timing question MAXIMUS1968 89-95 Toyota Pickup/Hilux 17 08-12-2006 10:28 PM
Timing belt question dario Camry & Solara Lounge 5 10-19-2005 07:31 PM
Part 2: Advancing cam timing allblackalltrac Hardcore Tech and Competition 0 04-16-2004 05:27 PM
