water leaking problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2007, 06:16 PM   #1 (permalink)
View bronxstreets's Photo Gallery
4th Generation water leaking problems
my 99 camry has a big problem,water keeps getting inside the car.everytime it rains the driver side backseat carpet and floormat are always soaked,little drops start dripping from under the steering wheel dash and one of the side holder things in the trunk is always full with water.
what u guys think on what should i do?i'll provide pictures later on the day
bronxstreets is offline   Reply With Quote
Old 10-02-2007, 02:29 PM   #2 (permalink)
View toyomoho's Photo Gallery
When attempting to find leaks visually look or run you hand to check for water and attempt to determine the highest point where the water starts. On the rear leak place you hand up on top of the frame where the trunk lid torsion springs mount and check for water.
Check for gaps in the body sealer under the roof molding and in the front and rear window sealer. Check for missing rubber body plugs. If you have a sunroof confirm the drain tube is clear.
There was a TSB out for front compartment leaking in the area you describe but it was for 02-06 Camry. Poor sealing of the engine compartment rear wall near the upper door hinge and inner frame box structure. You will need to remove the inner plastic wheel well to check these areas.
Start with checking the window seal on the side that water collects on.
Old 10-02-2007, 03:56 PM   #3 (permalink)
Young Toyota Tech
View Turboman412's Photo Gallery
this is a 99 camry? what model? does it have a sun roof? thats the first place i would look. check all the seals.. or put a hoes on the roof let it run and look for leaks
good luck
Turboman412 is offline   Reply With Quote
Old 10-02-2007, 06:07 PM   #4 (permalink)
good luck
its a 99 camry v6 ,it does have a sunroof that was custom made by the previous owner before my father bought it
Old 10-02-2007, 06:21 PM   #5 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
Ouch. Check that first.
Your trunk leaking problem could be one of these :
Water in the trunk coming from what looks to be left tail light assembly
This fixed my problem, but I'd have the sunroof checked (really) especially if it was custom made, then see if you still got water in the trunk. Cheap part, real easy fix.
Another common problem was that the condensation outlet hose for the AC system was clogged or routed inside the car instead of hanging out underneath. But that would passenger side I think.
Anyways good luck and if you find anything, pics would help. This kind of problem has to be adressed before electrical problems or rust problems start to appear.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Detailing your vehicle (Exterior) Pb Detailing & Car Care 222 05-15-2011 08:50 PM
Now I'm washing with warm (or hot) water Dana_15 Detailing & Car Care 9 04-16-2006 05:46 AM
Water leaking into 85 cab while raining jlangdon Pre-88 Toyota Pickup/Hilux 9 02-12-2006 02:50 PM
Water Leaking Into Cab etaylor05 89-95 Toyota Pickup/Hilux 1 01-18-2006 05:37 AM
water leaking from radiator. help games615 Camry & Solara Lounge 3 12-19-2005 07:17 PM
