poor gas mileage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2007, 08:56 PM   #1 (permalink)
View BowlofRice's Photo Gallery
3rd Generation poor gas mileage
I know there have been several threads and I read a lot of them. My gen 3 95 le 4cyc only gets 22mpg 70% city/30% highway. I used to get 26-28 but than the mileage dropped and hasn't gone back since. I have changed the spark plugs, wires, cap, rotor, air filter, and primary o2 sensor within the last 5k miles. The oil was just changed 3k miles ago. Tires a pumped to 34 psi. Any suggestions?
BowlofRice is offline   Reply With Quote
Old 10-01-2007, 09:06 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
how many miles on the car? when was the last time the throttle body or intake manifold were cleaned? if long ago or never then try that. does the car drive any differently?
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-01-2007, 09:06 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I get less than you...usually about 20-21 mpg with about 80/20 city/highway. My parents used to get over 400 miles to the tank...i can barely squeeze out just over 300. I dont drive with a lead foot...i usually keep it under 3k RPMs unless entering interstate.
I was getting about 19 mpg..but one day i sprayed some TB cleaner in the TB while the engine was running and it improved a little. I think I need to remove the TB and do a thorough cleaning of the IAC, EGR, TB, etc. to get my mileage up.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-01-2007, 09:12 PM   #4 (permalink)
the car has 159k on it. seafoam was run through the car at 149k ish.
this mileage is with me driving grandma style. going less than 3k rpm.
Old 10-01-2007, 10:24 PM   #5 (permalink)
View toyomoho's Photo Gallery
What was the color of the plug insulator when you changed them, white or black? Engine idle OK, how about power? Does overdrive engage? An injector or cold start injector may be leaking.
Old 10-01-2007, 10:42 PM   #6 (permalink)
The plug insulator was a bit yellow. Just a little at the top edge. The rest was white. Engine idles perfect at 800-900 and doesn't bounce. New thermostat too. Overdrive engages. How would I test for an injector or csi leaking? Wouldn't I smell fuel in the engine bay?
Old 10-01-2007, 10:56 PM   #7 (permalink)
Stillrunning posted that he had found evidence of leaking injectors by having his oil tested for excessive hydrocarbons. As i recall, he said that he removed the injectors, had them reworked, and that fixed the problem ...
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 10-01-2007, 11:28 PM   #8 (permalink)
What kind of place tests this type thing? Id like to know where I could take some oil to get it tested.
Old 10-02-2007, 12:30 AM   #9 (permalink)
blackstone labs is a place where you can get your oil tested. they send you some test tubes in the mail and you send the oil back to them and they give you your results. it cost around 20 bucks.
http://www.blackstone-labs.com/
maybe i should go get my oil tested.
Old 10-02-2007, 01:45 AM   #10 (permalink)
See Link here ... post #4:
1998 Camry 5SFE 4-cyl idle long-term fuel trim
send Personal Message to Stillrunning:
http://www.toyotanation.com/forum/49114-stillrunning.html
Old 10-02-2007, 07:56 AM   #11 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
since youre in washington, has the temperature dropped much? colder denser air will cause the engine to consume more fuel. about now is when my fuel economy starts to drop, but picks up again in spring.
Old 10-02-2007, 08:55 AM   #12 (permalink)
View wiccanferret's Photo Gallery
Try pulling the negative battery cable and letting the car's ECU reset. It's a free chance at fixing it...
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 10-02-2007, 11:21 AM   #13 (permalink)
Thanks for these...I think Im going to do this!
How long does the negative have to be disconnected?
Old 10-02-2007, 01:42 PM   #14 (permalink)
Not long, maybe 30 seconds. If you lose your radio presets then it was long enough.
Old 10-02-2007, 02:42 PM   #15 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
Just pull the ECU's fuse for the same effect.
thaharlequin is offline   Reply With Quote
91 celica gt gas mileage bluecelicagt Celica Forum 17 08-13-2011 08:31 PM
Plummeting Gas Mileage tjs99 1st Generation (1995.5–2004) 25 03-10-2007 11:51 AM
New EPA Testing Reduces Gas Mileage Estimates nodrogkam Toyota News 3 01-18-2007 08:04 PM
Buying A High Mileage Car? Your Opinions elvasoshexai General Discussion 21 03-06-2006 09:48 PM
