95 Tpyota Camry Xle V6 Acceleration problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2007, 09:19 PM   #1 (permalink)
View 01gixxer01's Photo Gallery
I have a 95 Toyota Camry xle v6, the Problem is the car take a while to start i need to hold the accel pedal down and once started the car idles fine and stays running until i try to accelerate then the car back files in the manifold and shakes and stalls,meanwhile all this is in the park position car will not drive cuz theres no power ive replaced the fuel filter,fuel pump, also ive changed the spark plugs and ive also cleaned the throttle body, checked the injectors to make sure there getting power, also checked the spark coil to make sure there getting power all that is fine and i took the timing belt cover to check if it slipped a notch but is tight and fine also..... Thanks in advance
01gixxer01 is offline   Reply With Quote
Old 10-03-2007, 12:11 AM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
I was actually going to say to check to see if the TBelt belt slipped.......Hmmmmmmm
Did you check to see if all 6 coil packs are still good?
5 Lug Corolla WHAT?
Old 10-03-2007, 02:28 AM   #3 (permalink)
Get a can of starting fluid .... while your assistant starts the car, spray intermittently into the air intake. If the engine sounds like it is running with the assistance of the starter fluid spray, this will give you a confirmation as to whether the problem is fuel related.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
07 Camry SE V6 Problem - Service Dept. Stumped - Comments? kkmatuse 5th & 6th Generation (2002-2006 & 2007-2011) 61 06-27-2009 01:45 AM
08 Accord EXL-V6 vs Camry SE V6 krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 12 10-01-2007 08:43 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
