95 Toyota Camry XLE V6- Updating problem please help
Once again Thanks for the people who replied on my last post much thanks, now im updating the problems once again, before i get to the next problem i have 2 very important questions that might help me in getting my car fixed, the fuel pressure regulator is hooked up to a vacuum hose if sensor is unplugged is the vacuum still suppose to work? question 2, i put a tool to check the injector power the light flashs fast as its suppose to and once accelerated hard the light its solid but it loses the light for a sec while acceleratoring does this mean theres something wrong with the computer since thats wat sends the signel to the injectors? now to the new problem the fuel pressure regulator is hooked up to the fuel rail and then to a vacuum hose and then to the fuel hose..... if i pinch the fuel hose hooked up to the fuel regulator the car accelerates perfect and doesnt stall..... wat could be the problem fuel regulator? Thanks in Advance once again.......
