i found this brembo Performance Street brake for $43.00 Closeout at tirerack.com but i'm not sure whether i should Get that or just get the OEM? is it gonna wearout quicket than OEM? also where is the OEM break pads at tirerack.com, i can't find it. btw it is for the 2000 Toyota Camry 4cyl and i need to change the front pads asap.
I got those brake pads, they wear out a little faster than the oem's. They also make a little more noise and brake dust. On the plus side they really increase your braking ability. A big difference between the performance of these and oem's.
ok thanks for the reply.... i just need to change the front brake pads only.... so if i want to go with brembo Performance Street brake can i just change the front pair with brembo and use the same stock Rotors? Can i change the Rear brakes later on or do i need to change all 4 at the same time?
also where can i find the prices for OEM brake pads?
The mechanic told me that i only need to chang ethe front pair but How is the performance gonna look like if i only change the front pads? what are the pros and cons for changing front pads only?
where can i find the prices OEM brake pads? I can't find it at tirerack.com
The majority of the braking power comes from the front brakes, so I would say changing the fronts only will still show an improvement, but not as much as if you changed all 4.
You cant change out the rear brake pads because there are drums brakes in the rear, unless its a v6. No you do not have to change the rotors and good choice with the brembos you'll be happy with them
what do you mean i can't change the rear brakes? what if they wear out?
