ignition problems please help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2007, 07:49 PM   #1 (permalink)
View camryfreak09's Photo Gallery
my friend has a 97 v6 auto. we tryed to start the car but it was dead, then u hooked up the bateries but it made a really bad clicking noice and wont start
camryfreak09 is offline   Reply With Quote
Old 10-04-2007, 07:54 PM   #2 (permalink)
Toyota Technician
-=]KaiN[=-'s Avatar
View -=]KaiN[=-'s Photo Gallery
sounds like a bad battery.
-=]KaiN[=- is offline   Reply With Quote
Old 10-05-2007, 06:00 AM   #3 (permalink)
Unco's Avatar
View Unco's Photo Gallery
yep, either that or the battery needs a good recharge, not just a jump start. how long was the car sitting without being started? get yourself a $20 battery charger and charge the battery overnight then try again.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 10-05-2007, 05:32 PM   #4 (permalink)
Gameroom cash: $303055
If you are hearing multiple rapid clicking noises, you have either a weak battery (battery itself or a problem with the charging system), poor or corroded connections at the battery post/terminal end or at the starter itself, or the cables running form the battery to the starter are drawing too much current. It also sounds like when you tried to jump start the car, one or more of the jumper cables did not make a good connection, or the jumper cables you used were too thin of a gage to carry the electrical load needed to start the car.
Mike
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
1989 ignition switch preciadoracing 4Runner Lounge 0 11-06-2005 06:50 PM
4A-F with programmable ignition and launch control Flashmn Archived Corolla threads 2 09-26-2005 02:19 PM
Ignition or starter problems spills1969 Hardcore Tech and Competition 2 01-18-2003 11:02 AM
