Drain the pan by removing the drain bolt ....remove the pan ... clean it .... replace the pan gasket .... refill the amount you have drained..... after driving awhile, drain again, maybe repeat drain/refill for a total of 3 times..... You will have essentially clean transmission fluid and probably extended the life of your transmission significantly....
That is if you haven't waited too many miles to do this already.
Use Dexron III ATF fluid for the transmission, power steering, and differential fluid.
Allow 3 quarts of fluid per drain procedure ...actual amount is about 2.6 quarts. Be sure and check fluid level and also for leaks before you take a long trip.
Be sure and clean the bottom of the inside of the pan well ... there is some sticky stuff that collects there.... Also clean and replace the two small magnet pieces that you will find.....Don't forget.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
