anyone no the front wheel bearing nut size? also what size bolt fits the brake rotor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2007, 02:34 AM   #1 (permalink)
View petermiddleton's Photo Gallery
try to pop off a rusted on front disc brake rotor, there are two threaded hole in the rotor can bolts be threaded in there to put pressure between the rotor and hub? if so anyone know the bolt size and should I get a higher bolt grade
what size is the hub reataining nut?
petermiddleton is offline   Reply With Quote
Old 10-06-2007, 03:05 AM   #2 (permalink)
I hate 5SFEs
conor's Avatar
View conor's Photo Gallery
3rd Generation
I forget what size the rotor holes are.. I have a nice box full of random metric bolts.. just dug through it until I found one =/ If you can't find the right bolt size, just spray the hub area of the rotor with lubricant or something like brake cleaner.. and smack it with a hammer. A lot. It'll come loose eventually
The axle nut is 30mm, however. You will need a deep socket to remove it. Shallow 30mm will not clear the stub end.
Conor :::: Life is blueish silver...
1993 V6 MR2
1986 MR2
1992 Camry LE
conor is offline   Reply With Quote
Old 10-06-2007, 05:57 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
The rotor removal holes should be 6 or 8 MM. Standard grade 5 from Lowes or Home Depot work fine. Use penetrating fluid. Not sure what conor meant by deep 30mm (yes I know what deep socket is) but usually sockets of that size are pretty deep anyway. I just used a standard 30mm. I would recommend 6 point not 12 point as the nut is fairly shallow and a 12 point will round the the flats more easily.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-07-2007, 02:05 PM   #4 (permalink)
Gameroom cash: $303055
The screw size is an M8. I believe the thread pitch is 1.25, but I am not absolutely certain of that. I use socket cap screws for this application since they are made of a very strong alloy. I just toss them in my metric thread assortment and they are easy to find for the next brake job, since they are the only socket cap screws in there.
Mike
Old 10-07-2007, 06:21 PM   #5 (permalink)
now bearing repack vs replace
you are right on both M8 1.25 I just bought them
Pepboys has the 30mm axle socket for 12.99
I am wondering about just replacing rather than repacking the bearings camry wagon tow hitch often pulling trailer 221,000 miles on it
Old 10-08-2007, 04:03 PM   #6 (permalink)
"I am wondering about just replacing rather than repacking the bearings camry wagon tow hitch often pulling trailer 221,000 miles on it"
I believe your car has non-servicable wheel bearings. You have to replace the whole assembly. If they are ok, I would just leave them alone.
Mike
Front inner wheel bearing not available, why? robkcmo T-100 2 04-16-2005 04:36 PM
Front Brake Rotor Stuck harryalder General Discussion 4 10-23-2004 02:27 PM
Size of front axle spindle bolt LexusES250 Hardcore Tech and Competition 6 07-19-2004 07:14 AM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
98 Corolla wheel bearing retainer nut size???? neil85AE86 Archived Corolla threads 0 12-03-2001 08:58 AM
