timing stuck at 10 degrees?!?!? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2007, 10:22 PM   #1 (permalink)
View drmotorhead's Photo Gallery
98 v6 TRD SC has been at the shop all of last week. I was barely able to drive it there. It was stalling when I gave it throttle. I had to baby it. Recently replaced knock and oxygen sensor. It keeps throwing the code for throttle position sensor, but we replaced that and it did not help. Also tried a new throttle body. Glad they are not charging me for their learning curve. Timing should vary by rpm, but it is stuck at 10 degrees.
Any ideas or suggestions?
2004 Toyota Sienna
1991 Acura NSX, 2710 lbs, 300 hp
1996 Ford Thunderbird Sport
drmotorhead is offline   Reply With Quote
Old 10-08-2007, 08:01 AM   #2 (permalink)
For the Gen 4 1MZ-FE, the Diagnostic Module ... see p. 202 of the online repair manual ... states that a P0100 DTC will cause the engine timing to be fixed at 10 deg. BTDC. This is to allow the car to be driven, until repaired.
This DTC would indicate some sort of problem with the Mass Air Flow sensor.
For the Gen 4, there is a platinum hot wire, used to sense air flow, that could be dirty, or possibly broken.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 10-08-2007, 09:15 AM   #3 (permalink)
Thanks! That diagnosis does match the problem. We will try a new mass flow sensor today.
2004 Toyota Sienna
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Lets run ignition timing at 40 degrees BTC... What? IHATERUST 89-95 Toyota Pickup/Hilux 14 10-13-2007 08:47 AM
Gas Mileage stumpfoot Pre-88 Toyota Pickup/Hilux 17 08-03-2007 01:42 AM
Ignition timing problem, can't adj to 0 deg TDC. shandar Pre-88 Toyota Pickup/Hilux 5 01-30-2007 08:45 PM
Timing mark for 45 degrees BTDC cwhutchings Camry & Solara Lounge 4 05-18-2005 12:12 PM
