3th gen - trunk does not close...need help!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2007, 08:42 PM   #1 (permalink)
View kongeee's Photo Gallery
Unhappy 3th gen - trunk does not close...need help!!!
hi,
when i open the trunk today, i notice i cant close it.
the lock on the trunk does not lock up.
i tried putting a screwdriver through it as if i was closing the trunk and the lock does not stay put. it opens itself again.
does anyone know what i can do to fix this?
thanks.
kongeee is offline   Reply With Quote
Old 10-08-2007, 08:53 PM   #2 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Originally Posted by kongeee View Post
hi,
thanks.
Do you mean that the latch isn't engaging (closing back shut?) Have you tried spraying some wd40 or some white lithium grease in the mechanism? The little spring that lets it latch back might've lost some tension.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 10-09-2007, 07:47 AM   #3 (permalink)
yes, the latch is not engaging. ive tried spraying wd40 already. ive tested to see if it engages and it does but the problem is after engaged, it goes back.
so it doesnt stay put.
Old 10-09-2007, 11:53 AM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
When you opened it..did you open it with the key or the pull latch from inside the car?
If inside the car...make sure that the cable is not staying pulled, thus keeping the lock from engaging. It's possible that the cable is binding somewhere and is keeping it from retracting.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-09-2007, 04:39 PM   #5 (permalink)
i open it inside with the latch.
the latch now seems pretty loose.
how do i check if its binding to something?
Old 10-09-2007, 07:04 PM   #6 (permalink)
Well..youll have to trace it from the pull latch inside the car. It runs down the driver side of the car. If you pull out the bottom of the back seat (no bolts) then you should be able to see it close to the edge.
You might be able to spray some wd40 or w/e your choise lubricant is down the cable and try to work it out. Take off the plastic piece that covers the trunk/gas pull latches and check it out. It's only 2 philips head screws.
They also make an actual cable lube (got mine from a harley shop) that is made for these type cables.
Old 10-09-2007, 07:27 PM   #7 (permalink)
all fixed. it seems like the plastic trim was in the way.
Old 10-09-2007, 09:47 PM   #8 (permalink)
Quasi-Evil Monkey
renmike's Avatar
3rd Generation
glad to hear that it's working now
gen 3 camry carbon fiber trunk importcars 3rd & 4th Generation (1992–1996 & 1997–2001) 30 04-05-2007 05:46 PM
Gen 5 versus Gen 6 body style... RICO8458 5th & 6th Generation (2002-2006 & 2007-2011) 39 02-20-2007 07:16 PM
The difference in gen 4's and gen 5's tightcamry129 3rd & 4th Generation (1992–1996 & 1997–2001) 18 09-12-2005 04:52 PM
Gen 3 trunk plate question crmartin9 3rd & 4th Generation (1992–1996 & 1997–2001) 3 04-06-2004 04:24 PM
