IAC / Spark plugs help GEN 4 5sfe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2007, 10:06 AM   #1 (permalink)
View gendos01's Photo Gallery
4th Generation IAC / Spark plugs help GEN 4 5sfe
Hi All
Camry i4 1999 - 156000m
I had a rough start issue . So , I cleaned my IAC , just spayed in it .. My Idle became very stable , however a little high. I took entire TB and IAC .. I cleaned IAC again (I did not take plastic part off ) .. When I assembled my IAC and TB back .. I have normal idle as far as RPM .. However , engine vibrates a bit .. I can see it also RMP jump somewhat +/- 10 .. (before cleaning it did not jump at all )
So My question is :
Could it be that curb cleaner (I sprayed a lot ) resulted in some kind of deposits on my spark plugs (have platinum OEM plugs - only 25k miles on these plugs) and therefore my engine is vibrating a bit ?
Should I buy new IAC ?
Should I reset ECM .. When I first started my car after reassembly of TB and IAC .. my engine almost stalled and vibrated a LOT for first few seconds . I've read somewhere that I should have reseted ECM before starting my engin ?
How do I reset ECM ?
Thank you
gendos01 is offline   Reply With Quote
Old 10-09-2007, 10:56 AM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
If you are still running on original spark plugs, you should probably replace them, and your plug wires are probably due to be replaced as well. Use Denso spark plugs and wires... that's the O.E. company that supplies them for Toyota.
BlueFusion6851 is offline   Reply With Quote
Old 10-09-2007, 11:00 AM   #3 (permalink)
4th Generation
Thanks .. I should add that I have relatively new platinum OEM sparkplugs only 25K .. I usually change my spark plugs 30 -40 k intervals
Old 10-09-2007, 11:10 AM   #4 (permalink)
How hard can it be?
Oh cool, you've already done the good thing then. I'm not sure how you would reset the ECU, and I'm not even sure if you can. Any help with this?
Old 10-09-2007, 12:05 PM   #5 (permalink)
atomix099's Avatar
View atomix099's Photo Gallery
I think you just plug out ur battery for a while... Thats how you reset the Engine check light im not sure about the entire ECU though...
Tork Imagine Gloss Black 18x8-9/ 14% Tint - 20% Rear Glass
Kenwood KDC-MP208 / Premier TS-W1241C x2
http://www.cardomain.com/ride/2371652
atomix099 is offline   Reply With Quote
Old 10-09-2007, 12:22 PM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
If you want to reset the ECU you should be able to disconnect the battery (usually the neg cable) for a couple of minutes and hook it back up. It takes about 50 - 100 miles of general driving for the ECU to re-learn everything.
On that note, how much have you driven since using the carb cleaner? It might take 5 - 10 miles to get the carb cleaner out. Also, was the "carb" cleaner rated for throttle bodies? I understand that there are some that tear up the inside lining of the throttle body somehow (They are supposed to be plastic friendly I believe). If you used a standard carb cleaner it may have damaged something.
Kep
Old 10-09-2007, 12:52 PM   #7 (permalink)
My TB is actually all metal (some kind of ) .. I used SynPower and Supertech , both are 02 safe .. I am not sure about plastic ...
I am so tempted to replace spark plugs (its $12 each at my stealership)
Old 10-09-2007, 03:59 PM   #8 (permalink)
Gameroom cash: $303055
"On that note, how much have you driven since using the carb cleaner? It might take 5 - 10 miles to get the carb cleaner out."
I have to agree with Kep on this statement. Just drive the car for a while to make sure all the throttle body cleaner is now out of the intake. Chances are the problem will go away on it's own.
If you really want to reset the ECU (which is probably not necessary) remove the negative battery cable and then step on the brake pedal.
Mike
Old 10-10-2007, 08:19 AM   #9 (permalink)
4th Generation
Well , I've been driving for about 200 miles .. It does not get any better . Yesterday I took negative cable off (did not do brake pedal ) . It did not help ..
I am thinking spark plugs got deposits or my IAC is malfanctioning (when I was cealning it , i used cloth and scredriver to clean behind a little moving 'door' . I did not take plastic part out of IAC - maybe I should have , it had some yellow paint marks on one of the screws , I fugured its calobarated os something )
I have dilema , should I take plastic part off and clean it again ? Should I buy new IAC or should I get new plugs ?
CAMRY COUPE part out! **take this stuff from me and build another camry with it** felkajamine Car Parts for Sale 122 02-07-2008 10:18 PM
Denso Spark Plugs for 1MZ-FE ptycamry Camry & Solara Lounge 10 01-05-2006 02:26 AM
Anyone using Nology Silverstone Spark Plugs TRD_Rob Camry & Solara Lounge 1 03-18-2004 12:28 PM
Difference between 3gen and 4 gen 5sfe WickedWerx 5th & 6th Generation (2002-2006 & 2007-2011) 0 04-11-2003 02:19 PM
Performance Spark Plugs for Gen 3 bigbodycam05 3rd & 4th Generation (1992–1996 & 1997–2001) 13 12-01-2002 01:14 AM
