3vz-fe oil leaks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2007, 10:35 PM   #1 (permalink)
Gen 3 Camry Lover
View sol4ris's Photo Gallery
3rd Generation 3vz-fe oil leaks
i just purchased my second gen 3 camry and i have an oil leak from somewhere on the aft cylinder bank to the exhaust manifold causing smoke. i also may have some fuel in the oil. (possible piston ring failure?) any tips on possible causes of my problem? thanks
sol4ris is offline   Reply With Quote
Old 10-09-2007, 11:23 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
well since its causing smoke then id venture a good guess that one place it may be leaking is from the valve cover on the back side. if u got fuel in the oil then u may be lookin at a bad ring.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-10-2007, 03:53 PM   #3 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Our Gen 3 V6 has a very slight leak which I believe to be from the rear valve cover. It's going to have to leak a lot more before I open that can of worms. Some things are easier to live with than to fix.
FWIW
YMMV
DFBonnett is offline   Reply With Quote
Old 10-11-2007, 04:15 AM   #4 (permalink)
Unco's Avatar
View Unco's Photo Gallery
FWIW
YMMV
they're not as difficult to replace as they are made out to be. you just need patience and a free afternoon.
on a side note, i used aftermarket gaskets and 4 months later they're leaking again. so beware. might want to stick to OEM gaskets.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 10-11-2007, 07:42 AM   #5 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
Our Aussie friend here is wise and correct.
The power steering pressure hose also runs back there over the exhaust.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 10-11-2007, 01:12 PM   #6 (permalink)
Gen 3 Camry Lover
thanks for all the tips guys
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Thick Oil in Camry Gen 5 cmathieu 5th & 6th Generation (2002-2006 & 2007-2011) 6 08-28-2007 01:49 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
