instument cluster lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 02:19 AM   #1 (permalink)
View wildcat47's Photo Gallery
My daughter has given me some projects on her 96 camry. Fix low beam lights, too dim and too low [fixed- 80%, i need to clean the lens covers or replace them]. replace drivers side door handle [ done]. lastly, to replace instrument cluster lights. i got to the point of having the cluster pulled out slightly, a connecting rod on right wont let me pull it out further and it seems something[probably wiring harness is holding it on the left] i need advise on where the bulbs are and how best to replace them. it seems that there are some wires going into the cluster at the top of the backside of the module. is this them? thanks in advance.
wildcat47 is offline   Reply With Quote
Old 10-10-2007, 02:23 AM   #2 (permalink)
sorry guys, i should have said lights in the ac control module area instead of instument cluster.
Old 10-10-2007, 12:23 PM   #3 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
On the HVAC unit, there is a screw behind the temperature knob. The knob can be pulled right off, and you'll see the screw, silver. The rods are also connected to a box that is a SEPERATE piece of the control unit. there is 4 clips holding it on. They seem easy to break, but they aren't. I've removed mine at LEAST 10 times without breaking anything. Let me know if you want me to take some pictures as I MAY have a spare unit laying around.
5 Lug Corolla WHAT?
Old 10-10-2007, 03:32 PM   #4 (permalink)
i remember seeing the screw behind the knob, but the clips you mention, are they holding the rod on the right side, the fresh air rod? also, are the bulbs in the front of the control module after taking the face plate off or are they in the back. i saw black double wires going into the upper back of the module. are these the light bulbs?
Old 10-10-2007, 05:14 PM   #5 (permalink)
OH, I forgot about the air knob, arg. I have an XLE, and it is with a button.
DL and read the following. It is the factory repair manual: http://camrymanuals.com/index.php?m=...=106&topicid=0
As for the bulbs, nothing needs to be taken apart to get the them. It's just like the rest of the bulbs, and they are in the back. 1/4 or 1/2 turn and they come out.
5 Lug Corolla WHAT?
Old 10-11-2007, 07:22 AM   #6 (permalink)
Thanks for you help. will be doing this sat morning. Hopefully all will go well.
91 Pickup Dash lights Lisa Sheree 89-95 Toyota Pickup/Hilux 10 03-13-2012 09:54 PM
Brake Lights Wolfcastle Archived Corolla threads 14 08-16-2006 11:55 PM
Help!!! No gauge lights... They worked yesterday! newbie212 89-95 Toyota Pickup/Hilux 6 05-31-2006 10:19 PM
how to check if all my cluster lights are working??? wontonjohnny Camry & Solara Lounge 2 03-01-2005 08:52 PM
1992 Corolla DX Customer Instrument Cluster garryconn Archived Corolla threads 2 04-24-2004 10:07 AM
