95 Camry Wheel issue or Bearing ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 09:34 AM   #1 (permalink)
View Steve.G's Photo Gallery
I have a 1995 Camry LE with 162k on the car. My problem is I have a scraping sound coming from the front drivers side wheel, sounds more like a tire scraping plastic. You can feel a slight scraping in the floor board at you feet. Not sure if it is just resonating to my feet thru somthing else ?
I replaced the brakes and rotors left and right sides along with the CV axle on the drivers side. My problem still exists. I thought maybe a wheel bearing or hub issue but cant get any movement out of the wheel when the car is jacked up and you try the side to side method.
I tried swapping out rims front to back with no help there either. I did notice a small area of the brake caliper where somthing like the rim had wore a groove into the rear area of the caliper as you look at it mounted on the rotor.
Anyone have any ideas ?
Steve.G is offline   Reply With Quote
Old 10-10-2007, 12:16 PM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Sometimes it can be more simple then you think. Did you check to see if the Rotor dust shield thingy (Metal backing) is bend onto the rotor making a scraping?
5 Lug Corolla WHAT?
Old 10-10-2007, 12:43 PM   #3 (permalink)
Yes I did that lastnight ( backing plate) when I swapped out the wheels from the front to the back. I even removed the hub caps.
I ordered a new hub and wheel bearing for the 1 side and will install it tonight, with any luck I will repost back here tomorrow morning with the results.
Just in case the hub might be tweeked or out of round and it might be rubbing the caliper is my reasoning behind just going new.
Old 10-10-2007, 01:30 PM   #4 (permalink)
Good luck and keep us posted. Hope it fixes it!
5 Lug Corolla WHAT?
Old 10-10-2007, 08:41 PM   #5 (permalink)
View NYC_99Camry's Photo Gallery
I think i have the same problem. I have a 99 camry with 81K and a year ago i installed the KYB suspension. recently i am getting a rattle sound on my rear right wheel everytime i go over a bump. it is really annoying. i am not sure if it is my wheel or my suspension......or maybe it is just a loose nut??? Please Help!!!!
NYC_99Camry is offline   Reply With Quote
Old 10-10-2007, 08:50 PM   #6 (permalink)
^ Check the sway bar LINKS and Sway Bar BUSHINGS.
5 Lug Corolla WHAT?
Old 10-11-2007, 09:49 AM   #7 (permalink)
Just a little update, I got my parts for the hub swap, but to my dismay, it came in pieces. I was short a 30mm deep socket to get the lock nut off for the hub also.
Question, because I now have to remove the spindal to replace the bearing and hub, how tuff is it to remove the bearing ? also how tuff is it to press the new bearing in.
I didn't see any new races in my box or a dust cover for the back of the spindal, how important is it to replace these items
I will up date this again tomorrow after I get the project done.
Old 10-12-2007, 04:50 PM   #8 (permalink)
3rd Generation
I pulled the spindle and hub set up off, and it was a wheel bearing that was making all the sound " plastic rubbing sound" from the drivers side front wheel.
The new bearing and hub is being pressed as we speak, so I should have it back together in a couple hours.
So the bottom line is, if your CV joints are new and you hear a speed specific rubbing and you get no side to side or in or out move from the wheel bearing. Chances are its still bad.
1994 Camry stalling issue y2k2s2k 3rd & 4th Generation (1992–1996 & 1997–2001) 6 11-14-2006 02:27 AM
How to change 95 camry transfer case oil? minime3 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-02-2005 04:15 PM
94 camry with 95 camry front bumper and rear trunk/lights? tousi 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-23-2005 04:55 PM
New here, suspension questions on a '95 Camry Patman36 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-17-2004 02:28 PM
