My car just shut off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 11:24 AM   #1 (permalink)
MDogg2199's Avatar
View MDogg2199's Photo Gallery
3rd Generation My car just shut off
driving home from work the other day and for some reason my car just lost power and every light in the dash went on. I had to force the car to the side of the road while it was slowing down. I shut it off for a few min. then turned it on and everything was fine. It's a 94 camry with 119,000 miles on it. I was just wondering what could cause something like that, especially because last week it just went in for a tune up.
-Brian
My 1994 Camry LE (Sold)
06 G35 6spd
MDogg2199 is offline   Reply With Quote
Old 10-10-2007, 12:12 PM   #2 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Check Engine Light?
5 Lug Corolla WHAT?
Old 10-10-2007, 12:44 PM   #3 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
The same exact thing happened to me twice with my '94, where the car just died, but i was able to start it up after. No CEL afterwards however. Has the timing belt been changed recently? (Although thats most likely not the cause)
geoff5093 is offline   Reply With Quote
Old 10-10-2007, 01:35 PM   #4 (permalink)
Gameroom cash: $303055
I'm going to take a couple of guesses here on things that go out when they heat up. First one is the fuel pump. Weak fuel pumps have a tendancy to quit when they get hot. The second is the coil inside the distributor. For both of these items you can drive to a mechanic when the car is running and have him test these items. For the fuel pump he will attach a pressure gage to the fuel rail and take actual pressure readings and compare them to spec. For the coil he will use a digital volt/ohmeter and again compare his readings to the specs in the manual.
Mike
Old 10-10-2007, 08:07 PM   #5 (permalink)
MDogg2199's Avatar
thanks for the responses. I found the print out from the tune up I got last week.
New spark plugs (platinum) denso double plat
new pcv valve
high press. fuel inj. filter.
clean and oil K&N filter.
and everything thing else wasn't engine related like wipers and nuts and bolts. do you think anything he did could of caused it. I don't think so but maybe there is something I'm over looking.
-Brian
06 G35 6spd
Old 10-10-2007, 08:10 PM   #6 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
what about your idle? could it be that?
CamrySExxx is offline   Reply With Quote
Old 10-10-2007, 09:27 PM   #7 (permalink)
View aznstylez's Photo Gallery
the high pressure fuel filter, was it installed correctly?
how much time did he take to clean and reoil the K&N air filter? If he reoiled the filter too much, the oil can mess up the MAF sensor.
aznstylez is offline   Reply With Quote
Old 10-11-2007, 11:29 AM   #8 (permalink)
MDogg2199's Avatar
I wouldn't know if it was, i don't do engine work. Where would I locate the fuel filter in the 1mz to see.
All in all I just want to know for personal knowledge, I'm actually looking at buying a new car very soon and if I can get anything for my camry I would like to sell it as a whole if not I might part it out.
-Brian
06 G35 6spd
Old 10-12-2007, 11:51 AM   #9 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
speed sensor
hoi hoi
OMNI is offline   Reply With Quote
Old 10-24-2007, 11:26 AM   #10 (permalink)
MDogg2199's Avatar
I test drove it again to see if it would shut off on me and it was fine until I accelerated past 40mph then it shut off. Is it a speed sensor problem or and Alt. problem?
-Brian
06 G35 6spd
Old 10-24-2007, 11:46 AM   #11 (permalink)
Banned
View RidinSpinners's Photo Gallery
Have you checked for codes even though you are not getting a CEL? Also, if the problem is repeatable: Is it shutting off at a certain speed or RPM range?
RidinSpinners is offline   Reply With Quote
Old 10-25-2007, 10:35 AM   #12 (permalink)
View skynyrdmh's Photo Gallery
This will happen if the crank sensor is going bad. Sends a bad signal to computer and will shut everything down. Took me a while to figure this one out on my "92.
skynyrdmh is offline   Reply With Quote
Old 10-25-2007, 12:04 PM   #13 (permalink)
View nitehawk55's Photo Gallery
Take it back to the shop that just did the tune up . You didn't have the problem before so it's possable they have done something .
nitehawk55 is offline   Reply With Quote
Old 10-25-2007, 12:09 PM   #14 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
my money is bad fuel pump.
a bad alternator will kill the battery on the car so the car probably wouldnt start again once it stalled. (plus wouldnt crank once it stalled)
when ive had a bad crank sensor, the car would go in limp mode so it wouldnt drive above about 35 mph and wouldnt rev above 3k RPM, but it never shut down the car, it would just stumble.
MKIV Scam registry bmw5002 Supra Forum 11 07-09-2010 11:59 PM
New info on the Toyota/Subaru RWD car JoeyW Toyota News 4 09-30-2007 05:09 PM
FS: 1986 Corolla GTS VanishingVision Vehicles 4 06-24-2007 04:52 PM
FS, 02 Benz Coupe Showcar joesc230 Vehicles 2 01-15-2007 08:32 AM
drove a new Scion tC 5 sp, not really impressed Talisman 1st Generation (2005-2010) 45 08-29-2004 08:08 PM
