How do I clean the strainer? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 09:16 PM   #1 (permalink)
View wahed3001's Photo Gallery
Hi fellas,
I'm dropping the transmission pan on my 94 camry (2.2L, 129K on the odo) this weekend for a proper drain and refill. I'm wondering what's the best product to clean the strainer/screen with. I'll be using brake cleaner to clean the pan but not sure if it's the right solvent to clean the strainer with. Any suggestions?
I've got new pan and drain plug gaskets from the dealer already. A new strainer was order only and cost $50! I'll just clean and reuse the one I already have.
wahed3001 is offline   Reply With Quote
Old 10-10-2007, 09:31 PM   #2 (permalink)
View toyomoho's Photo Gallery
Might use kerosene, diesel, etc to clean the pan and screen. Brake fluid may work but is much more expensive then the other solvents plus removes paint from surfaces and is generally bad stuff to work with. Most auto parts store either stock the screen or can order it at a much lower price.
Old 10-10-2007, 10:06 PM   #3 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
WOW! Mine came with the new gasket for about $25 at O'Rielly's. (like autozone, carquest etc). Anyway, it's metal, probably stainless, so don't think anything you use will hurt it.
Dave's is offline   Reply With Quote
Old 10-10-2007, 11:03 PM   #4 (permalink)
I was gonna use CRC Brake Cleaner not brake fluid. Sorry about the confusion.
http://www.ryderfleetproducts.com/cg...uct_detail.jsp
Old 10-10-2007, 11:16 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
The filter is cheap enough that you could just replace it and not worry about cleaning it. Most times when you buy the tranny pan gasket, the filter will come with it.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-11-2007, 10:49 AM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The strainer is about the thickness of a waffle with a screen sandwiched in there. All you're going to be able to do is try and shake out the big chunks and maybe run a parts cleaner (any of the above) through it backwards to dislodge any residue. You can't open it up to brush it out. Maybe dunk it in and out of a bucket of diesel 30 or 40 times. I wasn't willing to mess with it and went with the auto parts store combination gasket and filter. It was under $30 for both.
Kep
Keeping Engine Bay clean SBUBandit Archived Corolla threads 0 02-09-2006 04:19 PM
New Drive Clean Rules Phi General Discussion 15 12-04-2005 05:40 PM
To clean? crusty 2nd Generation (2005+) 15 11-02-2005 05:05 PM
Cleaning intake on Gen 7???????????? (i.e. Is there anything to clean??).......... redgtxdi Archived Corolla threads 1 09-17-2005 04:32 PM
How do you clean brakes? TOcorolla Archived Corolla threads 12 05-19-2005 12:46 PM
