The window goes up all the way, everything works great, but as it goes up it starts to tilt forward a little, and the back straight edge of the glass is coming out of the seal, along the back edge of the door. When this happens the glass can tip out a little and it will catch the small piece of rubber it should tuck behind. Then it bends it and then next time it is worst, bends it more, and so on. Until it is too the point I'm at now where the seal is shot. I should have a picture of this. I will try to get one up here, it will make more sense to see it.
I didn't think it was adjustable, it didn't look like it. I will have to slot the mounting holes of the regulator. Which I shouldn't have to do. I will use that as a last resort. But first I should take the glass and regulator out. And check that there isn't a worn part. Like a bushing that is allowing slop in the regulator.
