Suspesion Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2007, 07:35 PM   #1 (permalink)
View glenos's Photo Gallery
3rd Generation Suspesion Noise
I replaced the front struts on my 2.2L a few weeks ago, and since then I have noticed an odd noise when cornering. I would describe it as a squelching sort of sound but that is not right. It is not the knocking sound you get form CVs I know that sound well.
The history of the suspension is:
6 months ago replaced the sway(stabilizer) bar bushes (front and rear) with poly bushes, also the rear struts and new bump (spring bumper) stops, and the control arm bushes.
1 month ago replaced the front struts and bump stops, I reused the other rubber parts, (upper and lower spring seats).
I have a leak in my power steering, possibly the rack.
any suggestions?
glenos is offline   Reply With Quote
Old 10-12-2007, 07:59 PM   #2 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
when you installed the bushing, did you grease them up?
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 10-12-2007, 08:34 PM   #3 (permalink)
sure did, good and proper.
The noise has only been noticeable since I did the front struts. But there were lots of noises, knocks and thumps, before I changed them.
I think they were original, with 215k km on them so they were well and truely shagged.
Old 10-13-2007, 01:41 AM   #4 (permalink)
View toyomoho's Photo Gallery
Did you look at the upper strut mounts?
Old 10-13-2007, 02:11 AM   #5 (permalink)
View johno.b's Photo Gallery
did you grease the power steering rack,under boot cover.
johno.b is offline   Reply With Quote
Old 10-13-2007, 02:46 AM   #6 (permalink)
No, I didn't grease the rack under the boot.
I replaced the bump stop that goes on the strut rod, I didn't touch the upper strut mount (I assume you mean the rubber pad that goes between the spring and the body)
Old 10-13-2007, 08:02 AM   #7 (permalink)
View digmycelica's Photo Gallery
It may be something a simple as the backing plate may have got bent slightly and is slightly rubbing the rotor.
digmycelica is offline   Reply With Quote
Corolla rattling noise near drive belt area Momaru Archived Corolla threads 8 09-07-2006 12:57 AM
Weird noise. rogonzal 2nd Generation (2005+) 2 03-02-2006 02:17 PM
Help...excessive road noise islandx Tercel, Paseo, Starlet, and Sera Forum 5 02-01-2006 05:08 AM
Excessive wind noise 2005 Tacoma psmerdon 2nd Generation (2005+) 12 09-26-2005 03:18 PM
gen 4 suspension noise checklist Velox_camry 3rd & 4th Generation (1992–1996 & 1997–2001) 7 03-04-2005 10:11 AM
