Question about transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2007, 10:35 PM   #1 (permalink)
View cloudsearch's Photo Gallery
Hi all, I am new here and I found this forum so informative.
I have a couple of questions about my new old 97 camry.
1: I did not find the transmission dipstick under the hood? Also it is not mentioned in the manual either. I was told once I should change trans oil, so should I change half or flush? Thanks.
2: Is the power steering fluid using transmission fluid too? And the color is transparent yellow. Is it dirty that I should change it too? Thanks again.
cloudsearch is offline   Reply With Quote
Old 10-14-2007, 10:38 PM   #2 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
The trans dipstick has an orange top, should be clear as day under the hood. Keep in mind manual transmissions don't have dipsticks.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 10-14-2007, 10:42 PM   #3 (permalink)
Thanks. It is an auto one. Orange? I think I see one, which is to the down-right part under the hood?
Old 10-14-2007, 11:09 PM   #4 (permalink)
nuchieboy's Avatar
Gameroom cash: $203299
View nuchieboy's Photo Gallery
4th Generation
not to thread jack but why dont manual cars have dipsticks?
2009 Camry SE V6 loaded
Mods: Borla Dual Exhaust with no resonator, K&N Intake, 5k HID headlights and 5k HID foglights, LED Tail lights, Complete interior leds, Ultra Racing Front Strut Bar, Ultra Racing 19mm rear sway bar, 20% tint, Rosen navigation system, 19 inch ASA GT1 wheels
nuchieboy is offline   Reply With Quote
Old 10-15-2007, 12:01 AM   #5 (permalink)
R.I.P. Mick Karn
camrydriver7609's Avatar
View camrydriver7609's Photo Gallery
Your "new old" 97 Camry?
Well anyway, hope you found the dipstick now. I know people have said that transmission fluid should only be changed by mileage intervals and not by color. If you know how many miles you've put on it since it's last transmission fluid change, then just wait until you're at the right interval. Check the manual for details. If all else fails, call Toyota and they'll tell you.
If you don't know when the fluid was changed/flushed last and there is no way for you to find out for sure, check the color of the fluid. Pink is good. The darker the color, the older the fluid. Almost black fluid means CHANGE IT ASAP! Like, yesterday. Just to be on the safe side, if the color is way too dark, or it's been a long time since it's last change, do a flush. Get a new filter and gasket too. Why not? Let a mechanic do this if you don't know how to do it yourself. During a flush you can get globs of stuff stuck there and if not removed properly, it can get stuck in the gears and ruin your transmission.
If the fluid is a pink, just watch out for any leaks and keep an eye on the color. Like I said, tranny fluid change should be determined by miles and not color but unless you know the mileage for sure, what can you do? It's your call dude.
I believe power steering fluid should be power steering fluid. I don't ever recall seeing it in a clear yellow color. Maybe someone else can chime in here? If nothing else find a mechanic to help you out. Don't go to Toyota for work. They'll rip you off. Find a good Japanese car specialist to do the work for you. They're not as expensive as they sound.
'97 XLE V6 - 98% stock.
camrydriver7609 is offline   Reply With Quote
Old 10-15-2007, 01:44 AM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
No no no...Toyota power steering uses Dexron III ATF. If the stuff is yellow, it's the fluid from the factory. It's yellow because it doesn't have the red dye that you normally find in ATF. I'm fairly certain that it states Dexron III on the container or the cap.
2007 Camry 2.4L 5M
Old 10-15-2007, 01:47 AM   #7 (permalink)
Not really sure, but to check it, you just lift the car, take off the fill plug and stick your finger in the hole. The level should be right at, or very close to, the bottom of the fill hole.
2007 Camry 2.4L 5M
Old 10-15-2007, 07:52 AM   #8 (permalink)
Qslim's Avatar
I guess it's to the down right part... It's orange and on top of a vertical tube that comes right out of the transmission.
-- Get him, boy....
Old 10-15-2007, 08:46 AM   #9 (permalink)
I really appreciate your advice. I would locate the tranny fluid dipstick and check. I am not sure, but I think it was probably more than 20K miles since the previous owner changed the fluid.
Old 10-15-2007, 12:35 PM   #10 (permalink)
I found the dipstick. Thanks all. The tranny fluid still look quite red-ish. A quick follow-up question: if I am to fill the power steering wheel, and the old fluid is from original factory, can I just add new trans fluid or I need to drain the oil in the box first?
Old 10-15-2007, 02:35 PM   #11 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Take heed of what touringcamry said, do not use power steering fluid in the power steering reservoir! Use Dexron III automatic transmission fluid. Read your manual to verify this. Power steering fluid is not compatible with the Camry's steering system.
If you have under 100,000 miles, just adding the fluid to your power steering system should be fine. Over 100,000 miles you may want to consider using a baster to suck out the fluid from the reservoir and then topping off with new fluid. Do that 3 or 4 times in a month and you will have, essentially, new fluid.
If you decide to replace the transmission fluid, don't forget that there are two (separate) reservoirs that you need to change the oil in.
Kep
Old 10-15-2007, 10:20 PM   #12 (permalink)
Kep
The fluid should not be low unless there is a leak somewhere. If the level is fine, use something to remove the fluid from the reservoir and then fill with new fluid. Ensure that you do not remove so much fluid that you expose the hoses to air. You don't want air in the system.
2007 Camry 2.4L 5M
Old 10-16-2007, 11:15 PM   #13 (permalink)
View marc780's Photo Gallery
Thats a good question, wish i knew the real answer but i have a couple guesses. It doesnt have a dipstick for the same reason the rear axle on a rear wheel drive car doesnt have one either, not really necessary and shouldnt use any fluid under normal use (or even most kinds of abuse) for thousands of miles.
Also it would be an excellent feature to have a dipstick for your manual trans ( i wish i had one on my 4 speed Nissan truck, for instance) but the automakers apparently all figure that it is possible to get by without one, so they do - and they get to save a buck or two on every car they make (by no means a small consideration when you are a company selling 500,000 cars a year).
If you check your manual trans fluid by sticking your finger in the hole and the level is low, it means you have a leak, and thats that. The fluid level doesnt vary with the temperature of the transmission, like it does on an auto.
Old 10-16-2007, 11:26 PM   #14 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
just to clarify ... i posted this on a thread a few month ago:
look at that JDM writing on my caps
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 10-17-2007, 12:45 AM   #15 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Nice leaves there Venom
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
HELP!!! Weird/Strange Sound from Transmission after ATF Change junkyudog 5th & 6th Generation (2002-2006 & 2007-2011) 31 10-12-2007 09:09 PM
Transmission Fluid? cowboycorolla Archived Corolla threads 5 09-13-2007 08:41 PM
Differential Fluid Question on 98 Avalon RStocker1 1st Generation (1995-1999) 7 04-24-2007 12:09 PM
Tranny fluid question. djarno 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-04-2006 03:58 PM
