97 2.2l oil leak help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 08:20 AM   #1 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
i have a 97 camry 2.2L, i did all the maintenance myself,
i changed spark plugs, 4 grommets, valve cover gasket, cam seal, oil pump seal, oil pump o ring, crankshaft seal, timing belt, ps belt and AC/Alternator belt. drain and refill ATF 5 or 6 times, differential fluid 2 times, and replaced both Axle due to clicking while turning.
now i still find wet spot on the driver side of the engine, looks like it is somewhere below the valve cover gasket, i didn't have a chance to remove the intake hose to take a clear look,
the oil is black or golden brown color, and accumulates on top the transmission differential casing, in front of the vehicle speed sensor. then dripped down to transmission oil pan.
any expert has any idea where or which seal might cause the leak?
i think there is a rear crankshaft seal in there area, but that is all the way below the leak.
i didn't change the axle oil seals, the driver side axle seal is dry, but the passenger side axle case area is wet, i can't tell if it is leak from above or it is the axle oil seal itself.
but i look from under the car, i can see oil drip from the engine block and valve cover area on the driver side right around the igintion coil
please help
bronzemaxell is offline   Reply With Quote
Old 10-15-2007, 08:27 AM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Distributer shaft seal?
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 10-15-2007, 08:27 AM   #3 (permalink)
Former Toyota/ASE Master
Qslim's Avatar
View Qslim's Photo Gallery
The half moon seals are prone to leak if not re-sealed with RTV when you replace the vc gasket, and the distributor o-ring is also another common leak in that area.
-- Get him, boy....
Hello to my NSA pals reading this on Echelon
Qslim is offline   Reply With Quote
Old 10-15-2007, 09:10 AM   #4 (permalink)
this engine doesn't have distributor
when i did the valve cover, i did put some silicone on the half moon, and spray brake cleaner to wash off the oil grease, now that valve cover gasket is dry.
but the leak is below the valve cover gasket, it is some where at the ignition oil area.
i suspect oil seal somewhere at the circled RED area
oil accumulated in circled RED area at the transmission differential casing.
i see oil drip at the circled RED area.
wet spot at circled red.
DIY: Oil Change w/ pics 5.7L mhadden 2nd Generation (2007+) 14 02-05-2012 03:04 PM
oil leak front cover Q fast68 Pre-88 Toyota Pickup/Hilux 4 02-09-2007 01:06 PM
97 Camry Oil Pan Leak nobitanobi 3rd & 4th Generation (1992–1996 & 1997–2001) 8 05-15-2006 11:12 PM
Aggonizing oil leak! IMPORTMyth01 MR2 Forum 1 08-26-2004 11:29 PM
