Help! car won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 10:58 AM   #1 (permalink)
View Tubbyc's Photo Gallery
I have a 2001 Camry V6, for some unknown reason, the car won't start this morning, it was working fine yesterday, I know the battery is not dead, since the light still works, but when I try to start the car, I couldn't even hear the usual firing up sound at all. I want to know what is going on before have my car towed to the dealer, and does anyone know how much would it cost me to fix the problem?
Tubbyc is offline   Reply With Quote
Old 10-15-2007, 11:43 AM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
sounds like your battery is dead. there could be enough power to light the lights, but not enough to turn the starter on the car. try jump starting the car. were there any rapid clicking sounds?
Old 10-15-2007, 11:57 AM   #3 (permalink)
View Tarzan's Photo Gallery
I've had that happen. Drove it one night and next morning, nothing. Did you hear a click click click sound? If so, its most likely the distributor, which goes for $800 at the dealer. I posted a thead about it, search for my name and "car won't start" Good luck
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 10-15-2007, 12:04 PM   #4 (permalink)
yes, there is rapid clicking sound!! does that mean my battery is dead?
Old 10-15-2007, 12:05 PM   #5 (permalink)
ahhhh.. $800 bucks.. will it take long for them to install a new one?
Old 10-15-2007, 12:11 PM   #6 (permalink)
No, if they have the part in stock it will take 3-4 hours. The part itself costs around $350. The labor is what gets you. $800 for for labor, parts, and tow. Had I known for sure it was the distributor I would of gotten an aftermarket one for around $100 but i wasn't sure it was the problem so. It could also be the connections in the distributor cap. If thats the case then only would cost $20 at autozone. It is really hard to diagnose yourself though to see the real problem.
94 Camry Coupe
Old 10-15-2007, 12:34 PM   #7 (permalink)
View hooRAH's Photo Gallery
I wouldn't go jumping to conclusions. A no-start condition with a rapid clicking noise can very well be (and probably is) a bad battery.
I battery can have plenty of power to work the internal accessories and not have enough to start the car.
Try a jumpstart and go from there.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 10-15-2007, 12:51 PM   #8 (permalink)
considering my car already has 60000+miles on the odometer, guess anything can go wrong now
Old 10-15-2007, 12:57 PM   #9 (permalink)
nuinqua's Avatar
View nuinqua's Photo Gallery
Clicky, click sounds usually means your starter is bad....not distributor.
nuinqua is offline   Reply With Quote
Old 10-15-2007, 12:58 PM   #10 (permalink)
nuinqua's Avatar
What are you guys doing, posting at this time of day? Don't ya'll work?
Old 10-15-2007, 01:12 PM   #11 (permalink)
Can't it be both
Old 10-15-2007, 01:14 PM   #12 (permalink)
Ask yourself that question
94 Camry Coupe
Old 10-15-2007, 02:16 PM   #13 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I am with GhetoSled & HooRah. Rapid clicking indicates that there isn't enough juice left in the battery to engage the starter solenoid. The battery may or may not be the culprit. If your battery is good and the alternator isn't putting out enough juice or if the battery cables are coroded or if the battery connection is loose you could still get this condition. Make sure that your cable connections on top of the battery are clean and tight (you shouldn't be able to twist them by hand). Then try jumping it (give it 5 or 10 minutes to charge up the battery).
I am expecting it to be loose and dirty battery connections. However, if it takes the jump to start it take the car into a car parts shop. Most of them will test your electrical system for free and determine if the problem is the battery or the alternator.
Kep
Old 10-15-2007, 02:56 PM   #14 (permalink)
called the AAA guy, he came over, with the battery charger thing, the car starts right away, I guess I need a new battery then.. that's what he told me.. so which battery manufacture is good and reliable?
btw.. thanks guys!
Old 10-15-2007, 09:42 PM   #15 (permalink)
Interstate is the stock battery that came with our cars. I'm glad it was only the battery.
94 Camry Coupe
MKIV Scam registry bmw5002 Supra Forum 11 07-09-2010 11:59 PM
A few vip camry pics MattSWE Camry & Solara Lounge 95 07-29-2008 09:43 AM
My car won't start, help! sxv20 Camry & Solara Lounge 1 10-19-2005 03:46 PM
Car wont start denizen Camry & Solara Lounge 4 10-18-2005 02:00 PM
