The wiring diagram shows that the dash combination meter warning light could be for either the tail lights or the stop lights.
Definitely a good idea to remove all the suspect bulbs, examine the sockets and respective connecting wires. .... Look for signs of moisture, corrosion, or anything to prevent good electrical contact .... metal contacts should be bright and shiny.
If you find moisture, something is letting water get inside ...maybe use an electrically amenable grease. ...
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
