4 qts oil ok for 5S-FE? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2007, 12:09 AM   #1 (permalink)
View importcar's Photo Gallery
4th Generation 4 qts oil ok for 5S-FE?
I was changing the oil and put 4 qts instead of 3.8 qts. When I check the dipstick it is a few mm above full level. Is this bad for the engine or should I not worry about it?
importcar is offline   Reply With Quote
Old 10-16-2007, 01:06 AM   #2 (permalink)
View keithy's Photo Gallery
4th Generation
most ppl will tell you it's ok. I did the exact same thing once, overfilling slightly. The oil light came off, and I drove around for like 50k without a problem. But its annoying to see the light, and I re-did mine.
Something to add. I was driving on slopes/hilly area. If your diving in pretty much flat terrain, as long as there is no light, you're fine.
keithy is offline   Reply With Quote
Old 10-16-2007, 01:29 AM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
For over 80 thousand miles, I put 4 qts in my 2000 Camry I4. Never once did I ever have a problem with the oil light coming on. If you wanna talk hills, the first 40 thousand miles the car drove up and down the hills of San Francisco. The next 40 thousand were up and down the hills in the High Desert and up and down the hill on I-5 between SF and LA.
2007 Camry 2.4L 5M
Old 10-16-2007, 02:55 AM   #4 (permalink)
View unkit's Photo Gallery
3rd Generation
I just had my car serviced today. And my mechanic put in 4l. So i am assuming its okay. Bit surprised to learn that the oil light would come on if the oil is over... I always thought it would only come on if you didn't add enough.
unkit is offline   Reply With Quote
Old 10-16-2007, 06:49 AM   #5 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Unless you have an oil level switch the light is activated by pressure, not amount. 4 liters is less than 4 quarts. A little over fill won't hurt if you think that when you start the engine a lot of oil gets pumped throughout which will lower amount in sump.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-16-2007, 07:04 AM   #6 (permalink)
View hooRAH's Photo Gallery
You can overfill these engines by at least a quart and still be fine.
01 BMW 330Ci - 5spd / 93 BMW 525i 5spd-SOLD/ 98 Camry LE
hooRAH is offline   Reply With Quote
Old 10-16-2007, 02:43 PM   #7 (permalink)
You did the conversion wrong. 4 quarts, or one gallon, is 3.8 liters. thus 4 liters is going to be more than 4 quarts.
2007 Camry 2.4L 5M
Old 10-16-2007, 07:58 PM   #8 (permalink)
Thanks for everyone's input. I can drive with peace of mind now. I was just concerned because on page 224 of the owner's manual, it says to avoid overfilling. or the engine could be damaged.
Old 10-16-2007, 11:18 PM   #9 (permalink)
Gameroom cash: $303055
I put 4 quarts in my 98 5SFE engine for over 100,000 miles with no problems. If you let a hot engine drain for about 45 minutes to 1 hour when changing the oil and filter yourself, it will take 4 quarts to bring it to the full line. 4 quarts will not harm your engine. I did this until somebody rear ended the car about a year ago and totaled it. My 07 Camry with the 2AZ 4 cylinder engine takes 4-1/2 quarts to fill it back up. Now that is a pain. Did you ever try to put 4-1/2 quarts of used oil in a 1 gallon (4 quart) milk jug?
Mike
Old 10-16-2007, 11:22 PM   #10 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
4 qts is the correct amount - never caused me any trouble
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 10-17-2007, 08:32 AM   #11 (permalink)
Mike
Mike - Used laundry detergent containers are so much more convenient! They can hold at least 2 camry oil changes.
Now, try changing the oil in my 330Ci - thing takes 7 quarts! I usually use 2 of the 1 gal windshield washer bottles for that. Theyre slightly more robust than milk jugs.
Old 10-17-2007, 08:34 AM   #12 (permalink)
Yes, its great that you're paying attention to things like these. Like everyone said though, a little over (or even a LOT over) is okay. Just don't go putting 7 quarts in
Old 10-17-2007, 04:03 PM   #13 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
OK! Enough already! 4 quarts with the filter is fine. This stuff is not that critical. Sleep well.
DFBonnett is offline   Reply With Quote
Old 10-17-2007, 04:37 PM   #14 (permalink)
View Kevs Toy's Photo Gallery
2AZ capacity is 4 quarts, 5sfe is 3.8, and 3sfe is 4. Going a little bit over shouldnt be too determintal. I generally go with an even 5 on my 1mz and it barely reads over the mark. It's capacity is 4.8. I'd just rather not have to deal with accumulating oil containers with leftover oil till I got a quart to use.
Kevs Toy is offline   Reply With Quote
Old 10-17-2007, 06:05 PM   #15 (permalink)
2AZ capacity on the generation 6 is 4-1/2 quarts including the filter. Not sure on the generation 5.
Mike
DIY: Oil Change w/ pics 5.7L mhadden 2nd Generation (2007+) 14 02-05-2012 03:04 PM
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 01:17 PM
Switching to Synthetic jnoley07 2nd Generation (2005+) 141 10-01-2007 01:25 PM
oh Snap! Oil Oil everywhere!! Shogun1011 Pre-88 Toyota Pickup/Hilux 9 07-09-2007 04:46 PM
toyota settles law suit on engine geling/sludge teriboberry 1st Generation (1995-1999) 26 01-14-2007 09:51 AM
