Front End Noise
Hi Everyone,
I own a 1997 V6 XLE model with 249,000 miles on the odo.
Within the last 2 months I have changed the following items:
- 4 New Struts (front and back), The reason I changed them is due to one of the rears started to leak and they have been on the car since new, so I said time for new struts all around.
- Strut mounts (front right & left) along with the bearings between the strut plates.
- Sway bar links (front right & left) as they were shot completely and were producing a clink noise on bumps.
- 2 brake calibers (front right & left) as the one on the right was sticking so I decided to change both sides.
- 2 new front Rotors and pads (right and left)
- 1 new front left ball joint as the old one was shot. along with the lower control arm complete with new bushings.
- Driver side axle as the old one started to click and caused sounds on turns.
Now when I come to a complete stop or turn right mostly or when I turn left but very seldom I get a rub/grind noise from the front left area. (my friend said it is rubbing something), I checked the brake dust cover but this turned out to be not the culprit.
I have checked everything more than once and I had 3 different mechanics try to diagnose the problem and all said we have no idea what could be the problem.
I thought that the new axle might be defective and all three mechanics ruled this out along with idea of a wheel bearing as it does not howl at any speeds.
I am puzzled with this issue, I love the car and it has been very reliable to me and my family from day one and I am not ready to part with it.
Guys Any help or suggestions that you may offer will be most appreciated.
Thanks
Al.
