Headlight Aiming - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2007, 02:11 PM   #1 (permalink)
View nayanbsb's Photo Gallery
Headlight Aiming
How do i aim the headlights on a '94?
I looked everywhere and i couldnt find the damn thing.
nayanbsb is offline   Reply With Quote
Old 10-17-2007, 02:14 PM   #2 (permalink)
View aznstylez's Photo Gallery
94' what? If Camry. There is a screw on the back of each headlamp that is pointing up at 90 degrees. Use a 4head screwdriver and turn it.
aznstylez is offline   Reply With Quote
Old 10-17-2007, 02:15 PM   #3 (permalink)
Originally Posted by aznstylez View Post
94' what?
'94 camry xle v6
Old 10-17-2007, 03:43 PM   #4 (permalink)
View Tarzan's Photo Gallery
What he said. There is a screw next to the head lights. Just turn them.
94 Camry Coupe
Tarzan is offline   Reply With Quote
Old 10-17-2007, 04:50 PM   #5 (permalink)
I found the screw, but nothing is happening. The lights wont go up or down.
Old 10-17-2007, 06:55 PM   #6 (permalink)
View number73forlife's Photo Gallery
Shine your lights when its dark out up against a wall or something that you can tape out a level and vertical on. There should be 2 screws per lamp. When controls left to right on controls up and down. Might be hard to move but keep turning em. It happens little by little.
number73forlife is offline   Reply With Quote
Old 10-17-2007, 07:03 PM   #7 (permalink)
Registered User
View tooyoungtoodie's Photo Gallery
you have to take out your headlights so its be easier to adjust the headlight angle.
tooyoungtoodie is offline   Reply With Quote
Old 10-17-2007, 07:05 PM   #8 (permalink)
well i did that to clean the lens, but i didnt see two vertical screws behind the headlights, ill look again and see with wat i can come up with
Old 10-17-2007, 07:32 PM   #9 (permalink)
Unco's Avatar
View Unco's Photo Gallery
you mean take them out of the car? how are you supposed to align them when they're out of the car?
there are 2 screws per headlight. one adjusts up/down and the other adjusts left/right.
you can't just look at the headlight and check for movement up/down. it's never going to happen. you need to look at the light beam that it projects. so you need to do it at night perferably, on a flat road and maybe facing a wall from a distance of 10-20 meters.
on my ltd i actually did it on a flat road and looked at the pattern that it gave me on the road ahead, but on my camry it was easier to do it with the headlights shining on to a wall.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 10-17-2007, 07:53 PM   #10 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
HAHAHAHAHAHAHAHAHAHAH!!!!!!!!
I SERIOUSLY hope you are joking!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
headlight aiming.... twheat 2nd Generation (2005+) 5 07-04-2007 05:33 PM
Headlight aiming SOLVED (sort of) nobrainer Camry & Solara Lounge 0 06-29-2005 02:09 AM
Headlight aiming rule of thumb. BLUEMEANIE General Discussion 0 05-26-2005 03:20 PM
headlight aiming TypeZer0 General Discussion 3 08-30-2003 09:51 AM
Headlight aiming Dawgz Camry & Solara Lounge 6 09-07-2002 02:12 PM
