Amp Output - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2007, 06:29 AM   #1 (permalink)
View n0rad's Photo Gallery
Amp Output
I'm about to install 2 amps in my Camry and was just curious if anyone else has done this. (Or someone else that requires a lot of amps.)
How much amperage can a stock gen4 handle? Should I expect dimming?
Thanks.
1997 Toyota Camry LE
JBL GTO 75.4II / 601.1II
JBL Power P650C (Front) MTX TDX6903 (Rear)
2 Cerwin Vega HED-10
n0rad is offline   Reply With Quote
Old 10-18-2007, 06:39 AM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
i've had a 750W RMS monoblock amp running without issues.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 10-18-2007, 07:24 AM   #3 (permalink)
great! ill be running about 900W RMS total between the amps so that sounds good to me.
Old 10-18-2007, 11:02 AM   #4 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
it will dim the lights. im running 500w rms and it dims my light. if you drive around often with it blaring, it can be harsh on the charging system as it try try to keep up. also adding a capacitor will help reduce this problem and will increased the sound quality. at least it did in mine.
good luck!
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 10-18-2007, 11:41 AM   #5 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
big 3 + cap should help some or go all out on a high output alt. but that's overkill in a car if you gotta do that much work. LOL
http://i55.tinypic.com/oa6dj8.jpg
[TRD.jpn][TRD.usa][5Zigen][DDM][DENSO][BC][STICH][FEDERAL][STANCED]
ONE_to_HATE is offline   Reply With Quote
Old 10-18-2007, 12:10 PM   #6 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I definitely recommend a capacitor. Even if you don't have noticeable dimming, not having a capacitor can be very stressful on your alt and battery. Good preventative maintenance IMO, and it will allow your amp an extra "boost" if it needs it.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 10-18-2007, 04:39 PM   #7 (permalink)
roy7777's Avatar
View roy7777's Photo Gallery
I use a RMS 600W mono amp.
Every time when the bass come out, it dims the light.
After I add a 1 farad capacitor, the situation is better.
roy7777 is offline   Reply With Quote
Old 10-18-2007, 08:36 PM   #8 (permalink)
Black95Cam's Avatar
my friend did that to his tundra. but he running about 1325W RMS to 2 Crossfire BMF 15s with about 750W RMS to the mids and high. did a 147 on Term Lab. he went all out with bigger alt like 400 amps with 2 kenitc battery cell (forgot the series number but one big one to run the truck etc and a small one on the side), kentic power cell, 5 fared stinger cap, all AWG wires.. and yeah he use it for comp.
http://b7.ac-images.myspacecdn.com/0...16060337_l.jpg
Last edited by Black95Cam; 10-19-2007 at 02:48 AM. Reason: he ran a bigger amp for his mids and highs then i thought
Old 10-19-2007, 01:24 AM   #9 (permalink)
View aleem86's Photo Gallery
I run directed 1200rms amp and sum cheap 4 channel 400 per channel. I would recommend upgrading ur battery to a optima red or yellow and a cap or kenetic
aleem86 is offline   Reply With Quote
Old 10-19-2007, 03:53 AM   #10 (permalink)
View 94CoupeV6's Photo Gallery
Stinger batteries are also a good choice.
94CoupeV6 is offline   Reply With Quote
Old 10-19-2007, 10:33 AM   #11 (permalink)
Black95Cam's Avatar
and they cost a grip load too... also power master are pretty good batteries too.
Old 10-20-2007, 05:07 PM   #12 (permalink)
View simplyxtrippin's Photo Gallery
i don't think having a cap is gonna help your alternator keep up with the power demand. I thought the main purpose of a capacitor is to store energy so that when the power is needed, it can provide it with less voltage drop. It still uses the same amount of energy with or without the capacitor, either way the alternator still have to produce that power. Please correct me if i'm wrong. haha. this won't be the first time. :-)
simplyxtrippin is offline   Reply With Quote
Old 10-20-2007, 05:21 PM   #13 (permalink)
Black95Cam's Avatar
yeah that pretty much all it does. but when i added a cap to my system, the sounds has improve quite a bit. the mids doesn't distort at max volume, the high are ear pinching, the bass has a more tight punch to it even though its a ported box. the overall sounds improved in MY system. *it may vary from system to system upon on what a cap will do*
Old 10-20-2007, 05:25 PM   #14 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
^ a cap does exactly that...it only helps when you're pulling/needing more power than the battery can supply within a specified amount of time- i.e. extremely hard hitting bass that draws a crazy amount of current- thus, you get better quality sound and better response
but for dimming, the only thing that will help beyond "the big three" (which helps a bit in all situations) would be a higher rated alternator...
I used to run a 1800wrms system....and yeah...when the bass hit....it was nuts....
HaHa
Old 10-20-2007, 08:05 PM   #15 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
"The Big Three" are the three main ground wires in your car. The Battery to ground, Block to ground, and ALT + to battery. Doing "The Big Three" is replacing or augmenting these three wires with larger gauge wire to allow more current to pass through more easily.
http://www.the12volt.com/installbay/...TID=73496&PN=1
Blackhawk3D is offline   Reply With Quote
installing 4chan amp, hu 12v wiring question p2adan 1st Generation (1995-1999) 1 12-07-2006 08:45 PM
Setting up an active system. The basics cam2Xrunner Audio, Video, and Security - Tech 4 07-21-2005 03:04 PM
Basic Amp Install Instructions Phi Audio, Video, and Security - Tech 11 04-06-2005 02:25 PM
Amp Installation help dave_thomas Audio, Video, and Security - Tech 6 04-29-2004 10:53 PM
amp questions.. celicaboi Audio, Video, and Security - Tech 17 12-16-2002 11:37 AM
