1992 Camry LE stalled on startup, now won't start, no spark (continued)
Since the other thread was getting long, I thought it would help if sum up my problem and progress troubleshooting.
Camry worked fine Fri. Stalled after 2 secs when next used on Mon. No noises, just stalled like out of fuel (it's not). Fuel system appears ok (fuel pump jumpered works, fuel line feels solid). Pulled plugs, and they were wet with fuel. Replaced plugs and wires because they were worn. Tested for spark on two wires, NO SPARK. Pulled distributor cap. Tried to start engine and rotor spins OK. Rotor button on cap was stuck down. Worked it loose, reinstalled. NO SPARK. Removed cap again, as well as rotor and dust shield. Tested resistance of primary, secondary, and pickup coil; all within spec. Need help troubleshooting ignition circuit. So far only tested ignition power source (pin-3) and it was 12V when key to ON. Any help before I pull dash to ECM would be much appreciated!!
