Retain memories with new battery - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2007, 04:49 PM   #1 (permalink)
View lenjack's Photo Gallery
I'm installing a new battery in my '98 and thought of using one of those 9 volt battery minders in the lighter to retain computer memory. Then I realized the socket is switched, so that idea won't work. Any ideas on this?
lenjack is offline   Reply With Quote
Old 10-19-2007, 05:15 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Hard wire a 12v source to the battery terminals. The cap that I have for my stereo does that too.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 10-19-2007, 09:00 PM   #3 (permalink)
I was thinking along those lines. Could you elaborate, or suggest a "hot' source?
Old 10-20-2007, 01:06 AM   #4 (permalink)
View toyomoho's Photo Gallery
The radio receives 12V DC power from the Dome and Cig/Radio fuse. The Dome fuse is for the memory power. Wire up the new battery to the terminals with small diameter wire, then swap batteries. Or find a 12DC source such as a trickle charger and substitute this for the wires. Have someone help you to hold the cables or battery.
Old 10-20-2007, 04:50 AM   #5 (permalink)
Unco's Avatar
View Unco's Photo Gallery
just hook up a set of jumper leads to the battery terminals and another battery (on your parents car/spare battery?) kind of like jump starting the car. then swap the battery with the jumper leads still hooked up to the helping car or battery.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 10-20-2007, 11:29 AM   #6 (permalink)
View marc780's Photo Gallery
why do you need to do this, car alarm memory or something?
Old 10-20-2007, 04:59 PM   #7 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
This is why I keep watching this thread. I hope its for more than just the radio settings. Cuz if you're doing this JUST to save your radio presets....you're one LAZY bastard!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-20-2007, 05:09 PM   #8 (permalink)
View Bear95's Photo Gallery
Would it be for the airbags? I always wondered how long you could keep the battey disconnected be for the AB system would not work, and how does the dealer reset it?
Bear
Bear95 is offline   Reply With Quote
Old 10-20-2007, 05:15 PM   #9 (permalink)
Ive changed the battery in my car. It doesnt take long. Shoot..ive even had the thing disconnected for several hours and have had no issues with air bag lights or anything.
Old 10-22-2007, 05:23 PM   #10 (permalink)
daveart's Avatar
View daveart's Photo Gallery
ok this is not recomended but......start the car then replace the battery fast,it will still run with out the battery,you gat like a 1 min or so to reconect the terminals and then tighten the hold down bars,like i said some may say it dangerous,but ive seen many do it and nothing hapened,make shure pos and neg never touch
daveart is offline   Reply With Quote
Old 10-22-2007, 05:40 PM   #11 (permalink)
the honda killa
rholzboog's Avatar
View rholzboog's Photo Gallery
i know a guy that did that and it exploaded takeing all his fingers and leaveing burns all over it even took the hood off it was some fuck up shit
catch me if you can
rholzboog is offline   Reply With Quote
Old 10-22-2007, 05:50 PM   #12 (permalink)
Unco's Avatar
what exploded?
it's not the recommended method, but i can't see why anything would explode. does "it" also explode when the alternator fails? it's the same thing.
Old 10-22-2007, 06:24 PM   #13 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Yea, maybe on cars from the 70's. Who the fuck would do that on todays cars? fuckin idiots.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 10-22-2007, 06:36 PM   #14 (permalink)
Unco's Avatar
he said it's not the recommended method. why get so aggressive about it? if it's so bad that a reply needs to be finished with such colourful words, then back it up with reason. maybe you can explain why it is more dangerous to do it on a 90's car than on a 70's car?
Old 10-22-2007, 06:39 PM   #15 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I would do what another member posted. Use jumper cables connected to another battery, or a portable 12V power source and connect it to the battery terminals. Then remove the connectors from the existing battery while the 12v power source is still connected, and then switch them over. Don't take the battery out with the car running, i've heard it can wreck havoc with the alternator and electronics.
geoff5093 is offline   Reply With Quote
My Optima battery saga....... Remarkable 2nd Generation (2005+) 20 07-15-2007 08:49 PM
Battery dies after 3 -4 days capinoy 89-95 Toyota Pickup/Hilux 13 06-05-2007 10:37 PM
Battery Problems haux Camry & Solara Lounge 3 09-21-2006 12:48 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 09:21 PM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 03:29 PM
