Originally Posted by mnwelch
I am in the process of removing the drivers side axle. From what i have been reading in the Haynes manual. It says that all you have to do is just pry the axle out of the shaft. I have tried and it seems like it has snap ring or something. Because it is not budging a bit. By the way i have a 95 camry with the 5f motor. Also i just have this thing on jack stands. Any help or hints on how to get this thing out would be greatly appreicated.
Yeah, it pops out. There is a snap ring on the splines of the axle inside the diff, but it'll pop through if you give it a good solid pry. Lacking a pry bar, you can also put a chisel or big screwdriver in the little ridges of the inboard axle carrier (the one that butts right up to the diff) and give it a goo whack with a hammer.
One tip: it's good to have a second set of hands holding the axle when it comes loose. If the thing doesn't come straight out there's a chance you can shred the axle seal.
