Replacing o2 sensor with wideband - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2007, 05:10 PM   #1 (permalink)
View vdop69's Photo Gallery
Alright, need some help from the wideband gurus.
Car is a 2000 5sfe
My bank1 sensor1 sensor on the manifold is broken so I bought a wideband sensor from plx-devices(http://www.plxdevices.com/products/m300/).
I plan on going the ghetto way and splicing at the sensor since I do not have a pinout and looking at that ecu makes my head hurt.
Wiring Instructions: http://www.plxdevices.com/M-Series-C...gram_Small.jpg
I wired up the narrowband output to the white wire at the factory o2 sensor harness. Did I wire this up correct? Thanks
vdop69 is offline   Reply With Quote
Old 10-20-2007, 05:29 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
^ yup
basically, the grey wire that they mentioned in the diagram then replaces the output of the stock o2 sensor to the ecu
HaHa
Old 10-20-2007, 05:32 PM   #3 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
Car is a 2000 5sfe
from my experience,
i would rather remove the old one, and read the part number off the bank 1 sensor 1, then call dealer, local or online and get the oem replacement,
i've heard splice wires or aftermarket one works, a few months later, problem returns.
bronzemaxell is offline   Reply With Quote
Old 10-20-2007, 05:39 PM   #4 (permalink)
Originally Posted by Eye8Pussies View Post
^ yup
Ok, good to hear. However, I am a little confused as to why I have a cel at the moment and the car does run a little bit lean sometimes(16), I guess I need to stop by Autozone tomorrow to get that code read. In the instructions they mention installing a noise filtering capacitor on the o2 sensor input wire close to the ecu. Is this important?
Old 10-20-2007, 06:45 PM   #5 (permalink)
TN Pussy Man
interference is quite possible with the wideband. especially with power sources and power wires - suck as your amp's power cables, etc.
I actually had a bit of a problem with mine when I first installed it...I had the power source for the wideband hooked up to my stereo power, and it wouldn't stop making a whining noise...damn annoying, but it didn't effect the readings though
and the problem that you're having right now is fairly common. although there is a narrowband output for the wideband (after being processed by the sensor computer unit) the output signal does not always match the oem signals emitted by the oem o2 sensor- hence the bad tuning and the CEL.
So long story short, if the problem does not go away or you can't find any way to really solve it, the only solution (which I did from the very beginning since I know how picky the toytoa ecu's are- and specifically my 94 1mzfe ecu is) to replace the stock o2 sensor with an oem o2 sensor for the ecu to tune with, and then weld an extra bung on the y-pipe or down-pipe pre-cat to get the wideband readings.
this is actually the recommended and best way of install a wideband anyway
HaHa
Old 10-20-2007, 07:04 PM   #6 (permalink)
yea, never thought about the ecu being so picky with the different signals, but it makes sense. I was running the wideband in its own bung, but since my o2 sensor blew I figured I would take advantage of the output. Guess I'll just bite the bullet and shell out the money to the dealer. Thanks again for all the advice.
Old 10-20-2007, 08:42 PM   #7 (permalink)
TN Pussy Man
yeah...sometimes we just can't try and take the easy way out on these things, eh? hey...at least you've already got the bung welded, etc. So it's really just buying a new o2 sensor.
good luck!
HaHa
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Help: Replacing O2 Sensor B on '97 Camry spec_v_24 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-27-2011 08:50 PM
Replacing O2 sensor cubsalltheway 3rd & 4th Generation (1992–1996 & 1997–2001) 5 07-12-2006 03:13 PM
Replacing O2 sensor...universal...oem??? Durrby General Discussion 7 03-07-2005 07:45 AM
replacing O2 sensor, remove pass. seat? jamesgf Camry & Solara Lounge 5 11-14-2003 11:46 AM
