New struts,springs,mounts and new problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2007, 06:41 PM   #1 (permalink)
4th Gen Camry Owner
View kpszar's Photo Gallery
4th Generation New struts,springs,mounts and new problems.
I have a 1999 Toyota Camry Le with about 52,000 miles. During about 40,000 miles I had to replace my suspension. I bought new struts, springs and strut mounts and started to have new problems since. One of them are loud thumping sounds during turns on bumpy roads. I am pretty sure it might be the strut mounts. Second one is every time I turn then stop the car has a hassle to stop. Like the disks is warped but they are not. They has a struggle to stop and makes a large grinding sound. I have plenty of life on the pads and disks. The final problem is when I turn (like a curved snake road)It makes a rubbing sound and my tires are inflated and rotated. I took both wheels off to see if their is any evidence of rubbing but there was none then put the tires back on. And nothing change. Anyone had these problems and fix or found out the cause of this? Thanks
kpszar is offline   Reply With Quote
Old 10-20-2007, 09:38 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
This is a stretch but since no one has chimed in yet consider, if you do indeed have a bad strut mount then maybe, and I do stress maybe, would it be possible that the alignment of the brake caliper relative to the rotor might be changing enough during a turn that something begins to grind? When you can, you might want to pull the calipers off and see if there is any evidence (shine spots on normally rusty areas) of something rubbing on the caliper or the caliper rubbing on something. The edge of the rotor is often rusty unless it is fairly new. If that is shine it would be very suspicious. Same with the inside of the body of the caliper. It too is normally kind of rusty.
Anyhow, it's a thought. I just can't figure out why the strut mounts would fail so soon.
Kep
Old 10-20-2007, 09:49 PM   #3 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
I wouldn't think that would change anything with the brake assembly. It's all mounted on the lower endlink assembly.
Blackhawk3D is offline   Reply With Quote
Old 10-20-2007, 09:59 PM   #4 (permalink)
5S-FU
View Sniperdude's Photo Gallery
wheel bearings
Sniperdude is offline   Reply With Quote
Old 10-21-2007, 12:43 PM   #5 (permalink)
4th Gen Camry Owner
When I try to stop when driving strait and when I turn then go start a while is no problem but the problem is when I turn then beginning to stop when my wheels are strait forward, Like turning into a driveway. I just have to bring it in to a shop. My shop said that they have no clue what is causing this. This is about the 3rd time. When the disk is resurfaced a few days later it comes again.
Old 10-22-2007, 11:50 AM   #6 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
well i could bet that the strut noise is probably from where your springs are now seated, so there's a bit of play between the strut shaft, and cap. try tightening the center nut holding the strut on the top. dont worry about the strut shaft moving, it shouldnt, as there's a good amount of pressure on it.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 10-22-2007, 12:39 PM   #7 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
im gonna bet its the strut mounts doin that. mine have done the same thing and it was becaue a metal ring that was supposed to be present between the strut and the strutmount.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 04-12-2008, 02:56 PM   #8 (permalink)
Biscuit-Dough Hands
Lumberg's Avatar
View Lumberg's Photo Gallery
Exactamundo. The bearing that goes in between the upper spring seat and the strut mount is pretty delicate.
Green Camry R.I.P.
Black Camry R.I.P.
2004 Avalon
iPhone repair, cell phone repair in Washington DC, Rockville Maryland
Lumberg is offline   Reply With Quote
