rough acceleraction? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2007, 12:34 AM   #1 (permalink)
View wahed3001's Photo Gallery
Hello!
94 Camry I4 with 129k miles here. I can feel some vibrations on the gas pedal
while accelerating, as if I'm driving over a rough surface (which I'm not!). Any ideas what might be causing this 'rough' acceleration? Also some light pinging during hard accelerations (sometimes, not always). Thanks.
wahed3001 is offline   Reply With Quote
Old 10-21-2007, 08:06 AM   #2 (permalink)
View digmycelica's Photo Gallery
With the hood open, Drop this thing in gear, hold your foot on the brake and give it a good bit of gas for a second or two. see if the motor raises up on one side. do it again in reverse. I suspect the front motor mount . it's the one right in front of the radiator, and probably the small (dogbone) mount on the motor right above the timing belt area.
digmycelica is offline   Reply With Quote
22R dieseling and running rough aptosca Pre-88 Toyota Pickup/Hilux 6 03-15-2011 01:17 AM
got a few rough idle and vibration issues. any pointers please? previa_fanatic Previa Forum 8 12-22-2007 08:50 AM
Rough Throttle Issue white3ch0c0late Camry & Solara Lounge 12 05-16-2006 05:15 AM
2000 Solara, V6, Rough Running clr_118 Solara 6 03-14-2005 11:28 AM
Rough and shaky Camry png6778 Camry & Solara Lounge 9 09-23-2004 04:00 PM
