Originally Posted by black00
The code is PO440 and says EVAP Emission Control System Malfunction and says the cause could be: Vapor pressure sensor malfunction, Fuel tank cap cracked, damaged or incorrectly installed, Vacuum hose blocked, cracked, torn or disconnected, Hose or tube blocked, cracked, torn or disconnected, Fuel tank damaged, Charcoal canister damaged
The gas tank cap is fine, not sure what else to check
If you have properly installed you OEM gas cap....
then take a look at the link here ... post #1:
GEn 4 camry CEL fixed!!!
Maybe buy a can of throttle body cleaner, disassemble the EGR, and spray all holes, apertures, and orifices liberally.
Wait a while for everything to dry, reassemble, and see what happens.
Inspect vacuum hoses in the vicinity for loose ends and tight connection.
Just an idea though.... not completely sure it will work.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
