99 Camry Brake light on (help needed) thanks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2007, 11:02 AM   #1 (permalink)
View blueskyhding's Photo Gallery
4th Generation 99 Camry Brake light on (help needed) thanks
during my last two trip, the brake light cames on for less than a minute after I started my vehicle. My first thought is that I might press my hand emergency brake, but I didn't. After I play around with my hand emergency brake handle, the light went off. What could be wrong? Besides wired to hand emergency brake, what else is this brake light signal wired to?
BTW, ABS is normal. It went through the self check and went off by it self.
Thanks for your help.
blueskyhding is offline   Reply With Quote
Old 10-22-2007, 12:06 PM   #2 (permalink)
View Camry97LE's Photo Gallery
Have you checked the fluid in the Master Cylinder?
- Darren
Camry97LE is offline   Reply With Quote
Old 10-22-2007, 02:20 PM   #3 (permalink)
It's close to min level. Thanks for your reminder. I guess I need to top it off.
Old 10-22-2007, 02:55 PM   #4 (permalink)
Gameroom cash: $303055
That's correct. As you drive around the fluid in the resevoir sloshes around and the sensor will read that it has dropped below the minimum level. This will set off the brake light.
Mike
Old 10-22-2007, 04:39 PM   #5 (permalink)
View Kingdom934's Photo Gallery
The brake fluid light was on my Gen1 when after I did a bleed on brakes. I thought I had enough (It was between the 'min' and 'max'), but I had to top it off right at 'max' to get that light to turn off.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
WTB: 99 camry right(passenger side) headlight and corner light tomkang2000 Car parts for trade or wanted parts 0 10-01-2007 10:30 PM
H11 Headlights Burnes 5th & 6th Generation (2002-2006 & 2007-2011) 49 03-25-2007 09:03 PM
99 camry brake disc removal 2olforthis Camry & Solara Lounge 9 03-22-2005 12:24 PM
brake light on dash,, GO AWAY!! alieneyed Celica Forum 13 01-06-2005 01:15 PM
