Engine movement when shifting 2.2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2007, 08:37 PM   #1 (permalink)
View nitehawk55's Photo Gallery
I'm sure there is a Q&A section I could do a search for stupid questions like this and if so can anyone tell me where to find it ??
Question.... I am getting noticable movement when shifting , not excessive but noticable enough . Car is a 97 with the 2.2 5 spd . Would a mount , the one that goes to the strut tower be suspect ? Looks OK but does move when rocking the car in gear so it's possable the rubber is too soft ? Will just changing this one help or should I replace all ??
Thanks !
nitehawk55 is offline   Reply With Quote
Old 10-22-2007, 08:42 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
id inspect each one but the dogbone(the one attached to the strut mount) would be my first guess.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-22-2007, 09:09 PM   #3 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
i had a similar problem a couple years ago it was the lower motor mount
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 10-22-2007, 09:26 PM   #4 (permalink)
View digmycelica's Photo Gallery
The motor mount close to the radiator and the dogbone mount are usually the ones that give the most trouble
digmycelica is offline   Reply With Quote
Old 10-22-2007, 10:41 PM   #5 (permalink)
[g4.Rep]
Gameroom cash: $245932
View ONE_to_HATE's Photo Gallery
^x2
ONE_to_HATE is offline   Reply With Quote
Old 10-23-2007, 12:06 AM   #6 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Next question. When you accelerate, do you feel, hear a "clunk". also, how many miles?
5 Lug Corolla WHAT?
Old 10-23-2007, 12:25 AM   #7 (permalink)
Don't feel a clunk really , just some movement in the gear shifter that seems too noticable if you boot it and let up . I've rocked it with it sitting in gear and don't see any broken mounts but there is give in that "dog bone" at the strut tower .
Old 10-23-2007, 12:31 AM   #8 (permalink)
The front bottom mount should be ok then. Normally when that gives out, it makes a clunk when you hit the accelerator.
For the dogbone mount, take a much closer look at it. Move it around with your hands, and see if the rubber is cracked and ripped.
It may look fine at 1st glance, so look close.
5 Lug Corolla WHAT?
Old 10-23-2007, 02:05 AM   #9 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
and if it isn't good I'd suggest looking up the DIY way to fix it, and really really stiff fixed at that I hear. Forget what it was exactly, but they used like, weatherstrip adhesive or something to fill in the whole area where the rubber is to reinforce it. (around the center nut)
Blackhawk3D is offline   Reply With Quote
Engine revs when shifting a 6-speed russinseattle 2nd Generation (2005+) 12 05-20-2008 01:58 PM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
Engine Stalls when Shifting into Gear Tundra_SR5_4X4 1st Generation (2000–2006) 1 11-01-2005 06:36 AM
Camry 2.2 1992-96 engine Nico 3rd & 4th Generation (1992–1996 & 1997–2001) 10 10-09-2003 02:11 PM
