Your initial overheating sounds like the fan switch was not functioning if you did not hear the fans come on when idling. The problems now sound a lot worse. When the engine overheated and steam came out and you parked it, did you put water in without turning the engine on when it was still hot? Have you checked your oil level? The leak could be from a frost plug (crystal plug?) but on a 97 if you have kept the cooling system with 50/50 mix I doubt a frost plug. I do suspect a head gasket. If you are not mechanical I would take it to a shop and have it checked.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
