Optimal winter tire size - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2007, 02:47 PM   #1 (permalink)
View pcdawg's Photo Gallery
4th Generation Optimal winter tire size
What is the optimal winter tire size for the gen4 camry.
OEM 15" rims.
thanks!
pcdawg is offline   Reply With Quote
Old 10-23-2007, 03:10 PM   #2 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
Well, that rim usually gets a 205/65/R15, and that's what TireRack recommends even if you look up winter tires.
Did you have reason to think that you wanted a different size?
eddie926 is offline   Reply With Quote
Old 10-23-2007, 03:56 PM   #3 (permalink)
The Greatest
View CamNub's Photo Gallery
You might want to go even thinner imo..
CamNub is offline   Reply With Quote
Old 10-23-2007, 05:04 PM   #4 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Go the stock size. I have 205/65/15's on my Gen 3 V6, and go out driving in anything, and laugh at the stuck SUV's. :-D
5 Lug Corolla WHAT?
Old 10-23-2007, 05:14 PM   #5 (permalink)
felonyr301's Avatar
View felonyr301's Photo Gallery
If yours came with the 4 cylinder then it's 205/60/15 if you want the most accurate speedometer reading and if yours came with the V6 then just use the stock size!?!
felonyr301 is offline   Reply With Quote
Old 10-23-2007, 05:55 PM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Stock size (205/65R15) works fine. I have an extra sets of OEM steel wheels with studded-snow tires mounted on.
This cars handles well in the snow with the right tires. I passed my share of 4WD SUVs with this car as well.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 10-23-2007, 06:07 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
OEM 15" rims.
thanks!
Optimal is 195/65/15.
The narrower the tire, the less effort the car needs to 'plow' through the snow. Some studded tires work best too.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 10-23-2007, 08:37 PM   #8 (permalink)
Thanks!
I wasnt too sure if i could use 195/65 or 195/60.
That's the size i'll get then. I know that we can use the same size as the oem all-season. But for the witner its optimal to use a thinner tire so that less thread is in contact with the snow.
Tire size help for 2003 Highlander nhhighlander 1st Generation (2001–2007) 5 04-20-2011 11:33 AM
Need Winter Tire Recommendations for 07 Toyota Tundra 4x4 NickBrewer The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 09-12-2007 05:49 PM
Max tire size for gen 3? Winter tires.. Troyfrezze 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-28-2006 03:20 PM
Getting the right tire size for your wheel EKam Camry & Solara Lounge 3 11-29-2005 02:52 PM
largest size tire? 96camry4dr 2nd Generation (2005+) 2 07-28-2005 02:48 AM
