The factory recommended oil viscosity should be printed on the oil cap itself. My 96 5sfe oil cap has 10W30 printed on it, so that's the oil I use. As for brand, since your sticking to dino, I'd suggest Mobile. That's what I was using before switching to Royal Purple. You could also use 10W40 in your car during the hot months, since you live in Arizona. I wouldn't use anything higher than 10W40. Thicker oils reduce fuel economy if the engine wasn't designed to use it. Low-viscosity oils flow better than high-viscosity ones—the lighter-weight fluid is easier to pump and circulates faster through the engine. Low-viscosity oils also maintain a lower oil pressure, but the oil pump delivers a greater volume through the galleries than it would with thicker oils. Heavier oils also tend to operate at higher temperatures because the oil pump has to work harder to force the lubricant through the system. So, the added pressure increases the temperature. In the end, high-viscosity oils maintain a higher oil pressure, but the pump delivers a smaller volume of oil.
