Headliner question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2007, 08:10 AM   #1 (permalink)
View LineInTheWater's Photo Gallery
Headliner question
When I took my headliner off my camry, I found that a huge hole had been cut to accomodate both the aftermarket moonroof/sunroof AND the assembly into which it retracts. The headliner material had been glued to the remainder of the headliner board (only about 1 ft strip left) and to the metal assembly itself. Is it normal for the headliner hole to also be cut around the assembly?
LineInTheWater is offline   Reply With Quote
Old 10-24-2007, 11:52 AM   #2 (permalink)
Anyone???
Old 10-26-2007, 01:08 PM   #3 (permalink)
Heat's Avatar
View Heat's Photo Gallery
They probably needed to cut the headliner to get the assembly in. Remember, it's an aftermarket sunroof.
Anyway, I jut wanted to say that I just saw an ad from an automotive upholsterer for new headliners for $138 (installed). If this price range interests you, take a look in your yellow pages for upholsterers, then look for ads that include the word automotive (or something close). Call them and see what their prices are.
Heat is offline   Reply With Quote
Old 10-26-2007, 06:29 PM   #4 (permalink)
Heat, Unfortunately a brand new headliner would do me no good. It would not fit with the aftermarket sunroof. I would have to make my own headliner. Any suggestions on flat material from the hardware store that could be used as waterproof, warp-proof, lightweight headliner board??? I'm almost considering doing a two panel headliner (the original headliner on the outside, and a flat board in the middle). Don't know how that would look (probably look M-I-C-K-E-Y M-O-U-S-E).
2007 Camry Sound System Question mw817 5th & 6th Generation (2002-2006 & 2007-2011) 36 12-27-2006 07:33 AM
Sub/Amp question Elizle Audio, Video, and Security - Tech 5 07-13-2006 10:42 AM
Hell Question MR2Jedi Off Topic 11 07-06-2006 10:20 PM
2007 Camry Question skippy126 5th & 6th Generation (2002-2006 & 2007-2011) 5 05-24-2006 07:47 PM
general transmission question, 2nd, 4th and reverse do not engage!! afyouthbrigade Camry & Solara Lounge 1 09-29-2005 06:58 PM
